undefined reference
Old   July 21, 2016, 05:04
Default undefined reference
DANG
doubledang is on a distinguished road
Hi Foamers
I tried to develop a new library, but some strange linking errors appeared:
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::messageStream::masterStream(int)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::reduce(double&, Foam::minOp<double> const&, int, int)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::HashTableCore::canonicalSize(int)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::PstreamBuffers::PstreamBuffers(Foam::UPstre am::commsTypes, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&, int, int)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::UIPstream::read(Foam::UPstream::commsTypes, int, char*, long, int, int)'
/platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::UPstream::waitRequests(int)'
platformsnux64GccDPInt64OptbbPBE.so: undefined reference to `Foam::UOPstream::write(Foam::UPstream::commsTypes , int, char const*, long, int, int)'
collect2: error: ld returned 1 exit status
I am exhausted.
I really appreciate your input and help.
Best regards,
doubledang is offline   Reply With Quote
Old   July 21, 2016, 07:27
Hassan Kassem
hk318i is on a distinguished road
I am afraid, it is not easy for anyone here to help you without giving more details about your code. The problem is basically linking issue or problem with your OpenFOAM installation.
@HIKassem | HassanKassem.me
hk318i is offline   Reply With Quote
Old   July 21, 2016, 09:34
DANG
Hi Hassan,
Glad to have you here.
Basically, I was trying to use a PBE solver that was released at Github:
https://github.com/robertsawko/OpenPBE
These errors happend when I was installing (compiling and linking) it.
I have trying hard to solve it, but still failed.
I was curious what kind of reasons lead to the errors.
I reported the errors to the developer, but got no responses yet.
Could you please have a look at your convenience and give some help?
Best regards,
Old   July 21, 2016, 10:43
Hassan Kassem
I installed on my machine and I run the validation case using ``PBEFoam``. It worked fine. When exactly does this error appear?
Old   July 21, 2016, 10:56
DANG
Hello Hassan,
I have posted my compiling and linking processes at:
https://github.com/robertsawko/OpenPBE/issues/18
Could you take a look and see if you can find my origin of errors?
By the way, could you please share your installing steps?
Really appreciate!
Best regards,
Old   July 21, 2016, 10:59
Default interFoam
youssef morghi
djou is on a distinguished road
Hi
i hun interFoam solver and i have this result and stay going like this doesnt converge if some one know why
Phase-1 volume fraction = 1.2403e-06 Min(alpha1) = 0 Max(alpha1) =1 ,,,,,
Phase-1 volume fraction = 2.62429e-06 Min(alpha1) = 0 Max(alpha1) = 1
Phase-1 volume fraction = 4.17437e-06 Min(alpha1) = 0 Max(alpha1) = 1
Phase-1 volume fraction = 4.17437e-06 Min(alpha1) = -3.41753e-06 Max(alpha1) = 1
Phase-1 volume fraction = 5.87017e-06 Min(alpha1) = -2.97194e-06 Max(alpha1) = 1
Phase-1 volume fraction = 5.87016e-06 Min(alpha1) = -4.20485e-06 Max(alpha1) = 1
Phase-1 volume fraction = 7.58627e-06 Min(alpha1) = -3.92262e-06 Max(alpha1) = 1
Phase-1 volume fraction = 7.58627e-06 Min(alpha1) = -0.000100555 Max(alpha1) = 1
djou is offline   Reply With Quote
Old   July 21, 2016, 11:23
Hassan Kassem
Originally Posted by doubledang View Post
Hello Hassan,
Really appreciate!
Best regards,
I followed the same steps as you did. I think this error could be a problem in your OpenFOAM installation not in OpenPBE. Have you tried to remove it and reinstall? or at least have you tried to recompile OF?
Old   July 21, 2016, 11:25
Hassan Kassem
Originally Posted by djou View Post
Hi
I think this section of the forum is not suitable for your question. You will have to give more details about your case because the convergence depends on many parameters. No one can really help you based on these few lines.
Old   July 21, 2016, 11:45
DANG
Hello Hassan
Yes, I have recompiled the openfoam. But still failed...
Could you mind telling me which verion of OF do you use?
I have three versions of OF installed on my machine (don't know if this spoils).
The OS of my computer is Ubuntu LTS 16.04.
Best regards,
Old   July 21, 2016, 11:54
Hassan Kassem
I tested it on Ubuntu 14.04LTS and OpenFOAM-3.0 (pre-compiled version). There is no problem to have multiply versions of OF if your are sourcing the right version. Apart from OpenPBE, is your installation working fine?
Old   July 21, 2016, 12:03
DANG
My openfoam installation works fine for all the other applications.
What do you mean by "pre-compiled" version?
Do you mean it is unpacked OF source code folder?
The problem struggled me over almost 2 weeks.
I really exhausted.
Do you have any ideas or suggestions as to work around the problem
in my case?
Really Appreciate your input!
Old   July 21, 2016, 13:41
Mahdi Hosseinali
anishtain4 is on a distinguished road
In the github you provided it seems OF version 3.0 is needed. OpenFOAM had some fundamental changes in some of the version and most of the utilities will not be compatible if you use the wrong generation of OF.
Also you need Eigen 3 but the errors seem to be from OF.
anishtain4 is offline   Reply With Quote
Old   July 22, 2016, 04:28
Hassan Kassem
I really exhausted.
in my case?
I mean Ubuntu version, I didn't compile OF-3 on this particular machine form the source files, {LINK}
Based on your report in Github, you managed to install all the prerequisites successfully, that is why I though it is maybe related to OF installation.
Old   July 22, 2016, 06:01
DANG
Hello , Yes exactly, I also installed it successfully on my labtop this morning.
I have OF3.0.1 on my laptop.
So, I feel strange why it fails on my workstation.
Do you have any suggestions to get the reasons why it sucks on my workstation?
Best regards,
Old   July 22, 2016, 06:09
Hassan Kassem
Maybe it is related to Ubuntu 16.04 LTS, because I think pre-compiled OF-3 does not support Ubuntu 16.04
Old   July 22, 2016, 10:57
DANG
Thanks Hassan for your help!
I came to agree with you that is is possibly casued by Ubuntu sys.
By the way, could you hint how to run the validation case?
I have just install PyFoam.
But I have no idea as to how to use pyFoam.
Best regards,
Old   July 22, 2016, 11:04
Hassan Kassem
There is a code called setupCass.py in galinat just run it. This code creates few cases and it uses pyFoam
Old   July 22, 2016, 11:49
DANG
Yes, i have run the setupCases.py file, then some cases are established.
How could i run the cases such as re6400NC10 re6400NC20 ...
I tried to use pyFoamRunner.py, but failed.
Do I need to write pyFoam script to run them?
Thanks!
Best regards,
Old   July 22, 2016, 12:26
Hassan Kassem
I run blockMesh then the solver as any OpenFOAM case. Personally, I don't use pyFoam
Old   July 24, 2016, 10:00
DANG
Okay, thanks, Hassan
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 00:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
