error: cannot allocate an object of abstract type...
Old   October 24, 2013, 04:39
Default error: cannot allocate an object of abstract type...
Bojan Sekutkovski
Bojan is on a distinguished road
After successful compilation of OpenFOAM-1.6-ext on Ubuntu 12.04 64bit, i tried to add a compressible LES turbulence model to the library, i.e. kOmegaSSTSAS turbulence model. I managed to compile this model and use it within versions of OpenFOAM 2.0, and I got nice results. Making minor changes to the code, I almost have succeeded to compile it within the OpenFOAM-1.6-ext. The following error message appears after running command "wmake" or "wmake libso" (short version):
error: cannot allocate an object of abstract type ‘Foam::compressible::LESModels::kOmegaSSTSAS’
kOmegaSSTSAS/kOmegaSSTSAS.H:77:7: note: because the following virtual functions are pure within ‘Foam::compressible::LESModels::kOmegaSSTSAS’:
Or full version:
wmake libso
SOURCE=kOmegaSSTSAS/kOmegaSSTSAS.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/bojan/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/kOmegaSSTSAS.o
In file included from kOmegaSSTSAS/kOmegaSSTSAS.H:60:0,
from kOmegaSSTSAS/kOmegaSSTSAS.C:26:
lnInclude/LESModel.H: In static member function ‘static Foam::autoPtr<Foam::compressible::LESModel> Foam::compressible::LESModel::adddictionaryConstru ctorToTable<LESModelType>::New(const volScalarField&, const volVectorField&, const surfaceScalarField&, const Foam::basicThermo&) [with LESModelType = Foam::compressible::LESModels::kOmegaSSTSAS, Foam::volScalarField = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>, Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]’:
lnInclude/LESModel.H:128:1: instantiated from ‘Foam::compressible::LESModel::adddictionaryConstr uctorToTable<LESModelType>::adddictionaryConstruct orToTable(const Foam::word&) [with LESModelType = Foam::compressible::LESModels::kOmegaSSTSAS]’
kOmegaSSTSAS/kOmegaSSTSAS.C:44:1: instantiated from here
lnInclude/LESModel.H:116:9: error: cannot allocate an object of abstract type ‘Foam::compressible::LESModels::kOmegaSSTSAS’
lnInclude/LESModel.H:215:37: note: virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::compressible::LESModel::alphaEff() const
lnInclude/LESModel.H:116:9: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64Gcc46DPOpt/kOmegaSSTSAS.o] Error 1
Actually, I've found the problem...after removing the following line from kOmegaSSTSAS.C, the building goes successfully:
addToRunTimeSelectionTable(LESModel, kOmegaSSTSAS, dictionary);
I've been comparing kOmegaSSTSAS.C & kOmegaSSTSAS.H with other turbulence model files, but without a little success...
I'm not sure if I have to add some lines to files and options files in Make folder...?
Regards!
Regards
Bojan is offline   Reply With Quote
Old   November 5, 2013, 11:45
Default The solution:
Bojan Sekutkovski
After two weeks of searching for a solution, the problem was solved by adding the following function definition in kOmegaSSTSAS.H file:
//- Return thermal conductivity
virtual tmp<volScalarField> alphaEff() const
return tmp<volScalarField>
new volScalarField("alphaEff", alphaSgs_ + alpha())
Old   February 16, 2017, 10:08
Post Evaporation model
leofang is on a distinguished road
Hi Bojan,
I have encountered same problem when I am trying to implement an old code to OpenFoam 3.0 the message I am receiving is
error: cannot allocate an object of abstract type ‘Foam::MyEvaporationStA<Foam::ReactingCloud<Foam:: ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam: :ReactingParcel<Foam::ThermoParcel<Foam::Kinematic Parcel<Foam:article> > > > > > > >’
return autoPtr< baseType >(new baseType##Type parList); \
MyEvaporationStA is my own evaporation model which is under src/Lagrangian/intermediate/submodels/Reacting/PhaseChangeModels. I am just wondering how did you determine what virtual member needs to be added to the .C file.
Thanks a lot for your help
leofang is offline   Reply With Quote
Old   February 16, 2017, 15:36
Bojan Sekutkovski
Hi Leofang,
Actually, I have found problem inside of my error log, you can see it in my post. It is exactly at the end of error log:
Best regards!
Old   February 22, 2017, 12:02
Thanks for your reply Bojan. Unfortunately I still couldn't figure out how to change my source code to mitigate this problem. For your case do you remember why do your have to add virtual function to your header file?
Old   February 22, 2017, 12:26
Bojan Sekutkovski
I don't remember exactly, but I think I had to add the virtual function since it was defined in the base class of LES models, called: "class LESModel"
compressible, error, komegasstsas, lesmodel
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 10:12
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 15:12
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 08:13
