MultiRegionSetFields.C
Like Tree2Likes
  • 1 Post By Zeppo
  • 1 Post By Zeppo
Old   August 23, 2016, 22:24
Default MultiRegionSetFields.C
Bobby
babakflame is on a distinguished road
Dear Fellows
I am looking at multiRegionSetFields.C file inside OF and there are some lines that I can not understand. The followings start from line 129:
class iNew
        const fvMesh& mesh_;
        const labelList& selectedCells_;
    public:
        iNew(const fvMesh& mesh, const labelList& selectedCells)
            mesh_(mesh),
            selectedCells_(selectedCells)
Please correct me, if I am making mistake:
In the above , the class iNew has two constant private objects (mesh_ and selectedCells_) from fvMesh and labelList classes and a constructor (iNew) which has mesh and selectedCells as input arguments. However what is that ":"
and these two lines:
mesh_(mesh),
Another Question:
Why fvMesh and labelList classes are defined as References:
babakflame is offline   Reply With Quote
Old   August 24, 2016, 12:17
Bobby
Dear Fellows
I figured out my first question answer.
that
: mesh_(mesh), selectedCells_(selectedCells)
is for initializing fields inside constructors. its equal to
mesh_=mesh;
seectedCells_=selectedCells;
However, my second question still holds,
Old   August 27, 2016, 13:48
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Originally Posted by babakflame View Post
that
mesh_=mesh;
No, they are not the same. Whenever the workflow of code execution reach constructor's body (an openning curly bracket {) all class member variables have allready been initialised (constructors have been called) - either explicitly with initialisation list (follows colon :) or implicitly with a default constructor. In the constructor's body (between { and }) you can only call an assignment operator to assign a new value to any allready existing class member variable.
Because when you construct an abject of this class you want these member variables to point to the existing objects not to create new ones, right. If they were not references but values then the constructor would have to create new copies.
babakflame likes this.
Zeppo is offline   Reply With Quote
Old   August 27, 2016, 14:14
Bobby
Thanks Sergei.
Just for clarifying:
HTML Code:
Are u considering "mesh_ and selectedCells_" in the following snippet as variables or objects?
Old   August 27, 2016, 18:02
Zeppo's Avatar
Sergei
I believe mesh_ and selectedCells_ are called "member variables" and they are part of an object of iNew class. The word "variable" might imply that it can vary or be modified, but no, variable can be constant as well. And to confuse you even more, member variables are objects at the same time
