August 28, 2016, 19:50 |
Reduce() and Size() functions
Bobby
Rep Power: 15 |
Dear Fellows
I have few questions regarding the following snippet: Code:
scalar ULeft = 0.0; label leftI = mesh().boundaryMesh().findPatchID("left"); const fvPatchVectorField& fvp = U.boundaryField()[leftI]; if (fvp.size()) { ULeft = fvp[0].x(); } reduce(ULeft, maxOp<scalar>()); I assume the size of fvp is non-zero, so the "if" loop executes. My first question is on Code:
ULeft = fvp[0].x(); here, fvp is an array of vectors, since it keeps the velocity vectors of a patch, but the above command just stores the first component ".x()" of first vector "[0]" in the array of vectors. Am I correct? For example assume fvp = { (1 2 3) (4 5 6) (7 8 9)} then fvp[0].x means 1 then why using the Code:
reduce(ULeft, maxOp<scalar>()); I assume that reduce() function with maxOp<scalar> finds the biggest scalar in an array of scalars, but here ULeft just has one member!!! (in my example 1) Am I missing sth? Regards |
August 29, 2016, 03:47 |
Rep Power: 12 |
Hey,
i assume you have this snippet from the potentialFoam/cylinder tutorial ?! In the 0/U file you can see that they use a uniformFixedValue velocity (1 0 0) on the left boundary condition. Because you have the same velocity on each boundary face of the left BC itīs ok to just ask for a single element of fvp. Because you just have the x-component of velocity itīs also ok to just ask for fvp[0].x() ! Of course this is not very generic or reusable for other cases. When you decompose the domain (parallel computing with MPI) you just get the correct velocity from the process (or processes) which compute the subdomain containing the left BC. Other processes will return a null velocity. The reduce operation searches for the maximum value in your parallel processes on the left BC which will be a 1. By not using the reduce operation there is a risk that the master process is not computing the part which contains the left-BC and hence returns a null velocity. |
August 29, 2016, 17:35 |
Bobby
Rep Power: 15 |
Hey Traction,
Yeah, I was reading the code snippet available in OpenFOAM Programmers guide 3.0.1. Thanks for your clarification. Since I did not go through the whole sample case. I just read the code. But with your suggestions, my questions regarding the code snippet is responded. |
August 30, 2016, 15:42 |
Bobby
Rep Power: 15 |
Dear Fellows
I have another question regarding this snippet inside O.F. programmers guide version 3 (page 49) . Code:
dimensionedScalar uInfX ( "uInfx", dimensionSet(0, 1, -1, 0, 0), ULeft ); Code:
volScalarField error("error", mag(U-UA)/mag(UA)); Info<<"Writing relative error in U to " << error.objectPath() << endl; Here, just a 0 folder was present, However in case of more time steps what would happen? Last edited by babakflame; August 30, 2016 at 18:29. |
August 31, 2016, 02:58 |
#5 | ||
Rep Power: 12 |
Hey babakflame,
The OpenFOAM C++ Documentation says that objectPath() is a function to return the complete object path and the name of the object (in this case of the object error which is located in the current time directory). In this case it just produces an output on your screen / log file to find the location of the written error file. Keep in mind that potentialFoam is independent of the time. If there would be a suitable solver with time dependency OpenFOAM would write the calculation results for the fields "UA" and "error" for every timeStep. |
August 31, 2016, 16:39 |
Bobby
Rep Power: 15 |
Hey Traction,
Thanks bro for your comprehensive response. |
September 2, 2016, 15:05 |
#7 | |
Sergei
Rep Power: 21 |
For example U-UA is computed with this code: Code:
//-- src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricFieldFunctions.C ... 616 template \ 617 <class Type1, class Type2, template<class> class PatchField, class GeoMesh> \ 618 tmp \ 619 < \ 620 GeometricField<typename product<Type1, Type2>::type, PatchField, GeoMesh> \ 621 > \ 622 operator op \ 623 ( \ 624 const GeometricField<Type1, PatchField, GeoMesh>& gf1, \ 625 const GeometricField<Type2, PatchField, GeoMesh>& gf2 \ 626 ) \ 627 { \ 628 typedef typename product<Type1, Type2>::type productType; \ 629 tmp<GeometricField<productType, PatchField, GeoMesh>> tRes \ 630 ( \ 631 new GeometricField<productType, PatchField, GeoMesh> \ 632 ( \ 633 IOobject \ 634 ( \ 635 '(' + gf1.name() + #op + gf2.name() + ')', \ 636 gf1.instance(), \ 637 gf1.db(), \ 638 IOobject::NO_READ, \ 639 IOobject::NO_WRITE \ 640 ), \ 641 gf1.mesh(), \ 642 gf1.dimensions() op gf2.dimensions() \ 643 ) \ 644 ); \ 645 \ 646 Foam::opFunc(tRes.ref(), gf1, gf2); \ 647 \ 648 return tRes; \ 649 } ... |
September 2, 2016, 15:36 |
Bobby
Rep Power: 15 |
Thanks sergei.
I read this part that you send me. It seems that both add and subtract operations are done by this snippet. (overloading operators) Am I correct? Last edited by babakflame; September 3, 2016 at 18:43. |
September 9, 2016, 12:36 |
#9 |
Sergei
Rep Power: 21 |
Yes, that code is a part of a macro which generates both
operator + ( const GeometricField<Type1, PatchField, GeoMesh>& gf1, const GeometricField<Type2, PatchField, GeoMesh>& gf2 ) Code:
operator - ( const GeometricField<Type1, PatchField, GeoMesh>& gf1, const GeometricField<Type2, PatchField, GeoMesh>& gf2 ) |
Reduce size of Ansys.rst file in FSI simulations? | Jorn | CFX | 6 | September 21, 2017 03:00 |
[ANSYS Meshing] Reduce mesh size only in one direction | peppe7 | ANSYS Meshing & Geometry | 0 | January 29, 2016 13:22 |
How to reduce size of autosaved .sim-files? | adbuerger | STAR-CCM+ | 8 | October 12, 2015 09:36 |
How can reduce the size of figures in Ms Word | immortality | Lounge | 1 | February 6, 2014 03:24 |
Reduce output file size!! | Jonac | CFX | 1 | September 15, 2000 03:24 |
