OpenFoam ensure same values across processor patches |
January 2, 2018, 17:58 |
Rep Power: 12 |
I am calculating averages on physical boundaries of my domain. However when I am calculating these things in parallel my solver crashes. Because, my calculation happens on processor patches too. As my calculation has some stochastic component to it, the values across processor patches are never exactly same. For example face values on procBoundary0to1 on processor 0 won't be same as procBoundary1to0 on processor 1. I tried keeping my face values at procBoundary* to 0 and even tried not doing anything at all. However it seems I need proper values there. So How can I ensure procBoundary0to1 on processor 0 = procBoundary1to0 on processor 1. It seems i can't reduce or synchronize fvPatchScalarField&. |
January 2, 2018, 18:12 |
Simplified code snippet
Rep Power: 12 |
Here is a simplified code snippet
forAll(T_.mesh().boundary(), patchi) { //here patchi also includes procBoundary, I can get it's patchid and name just fine const fvPatchScalarField& pZ = Z_.boundaryField()[patchi]; forAll(pZ , facei) { if(pZ<MIN_VAL) { // do deterministic calculation } else { //do stochastic calcuation } } } |
January 7, 2018, 10:26 |
Hrvoje Jasak
Rep Power: 33 |
You should not be doing this. The processor0To1 and processor1To0 actually rerepsent the same face, on two processors. If they are inconsistent in ANY WAY, this is no longer the same face.
Think of this as 1 single internal mesh face: you need to repeat the exact same operation, but fetching the data in a different way - using patchInternalField() and patchNeighbourField() If you do anything else, the code may appear to work, but you will break the linear algebra package. Hope this helps, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 10, 2018, 20:20 |
#4 | |
Rep Power: 12 |
Here is a simplified code snippet THIS DOESN"T WORK! Code:
forAll(T_.mesh().boundary(), patchi) { const fvPatchScalarField& pZ = Z_.boundaryField()[patchi]; const fvPatch& curPatch = T_.mesh().boundary()[patchi]; std::string patchName = curPatch.name(); //if (isA<processorPolyPatch>(curPatch)) if(patchName.rfind("procBoundary",0) == 0) { const scalarField ppZ = pZ.patchNeighbourField(); //pZ.patchInternalField(); forAll(ppZ, facei) { if(ppZ<MIN_VAL) { // do deterministic calculation } else { //do stochastic calcuation } } } else { forAll(pZ , facei) { if(pZ<MIN_VAL) { // do deterministic calculation } else { //do stochastic calcuation } } } } Code:
forAll(T_.mesh().boundary(), patchi) { const fvPatchScalarField& pZ = Z_.boundaryField()[patchi]; const fvPatch& curPatch = T_.mesh().boundary()[patchi]; std::string patchName = curPatch.name(); //if (isA<processorPolyPatch>(curPatch)) if(patchName.rfind("procBoundary",0) == 0) { pT.evaluate(); //or pT.evaluate(Pstream::blocking); //all other patchFields follow } else { forAll(pZ , facei) { if(pZ<MIN_VAL) { // do deterministic calculation } else { //do stochastic calcuation } } } } Last edited by fedvasu; January 10, 2018 at 20:27. Reason: remove superflous detail |
January 10, 2018, 20:25 |
Final solution
Rep Power: 12 |
I would like to post THIS WORKING solution again for clarity.
forAll(T_.mesh().boundary(), patchi) { const fvPatchScalarField& pZ = Z_.boundaryField()[patchi]; const fvPatch& curPatch = T_.mesh().boundary()[patchi]; std::string patchName = curPatch.name(); //if (isA<processorPolyPatch>(curPatch)) if(patchName.rfind("procBoundary",0) == 0) { pT.evaluate(); //or pT.evaluate(Pstream::blocking); //all other patchFields follow } else { forAll(pZ , facei) { if(pZ<MIN_VAL) { // do deterministic calculation } else { //do stochastic calcuation } } } } Anyone knows exactly what evaluate() does and how it avoids my problem feel free to add to this thread. I will keep this thread unsolved till then. |
openfoam-2.4.0, parallel, random perturbation. |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
chtmultiregionsimplefoam: different pressure values in openFoam and Fluent | vasava | OpenFOAM Running, Solving & CFD | 0 | November 7, 2014 03:35 |
OpenFoam output to CSV; correlate coordinates to internal values | CoolKau | OpenFOAM Post-Processing | 0 | October 29, 2014 08:03 |
