OpenFOAM 4.x: pow function cause floating point error |
September 11, 2016, 09:13 |
SSSSS
Rep Power: 14 |
I want to do some calculation with point coordinate with pow function. The code is roughly as follows: Code:
const pointMesh& pMesh = pointMesh::New(mesh); vectorField coord = this->points0(); scalarField sf(this->points0().size()); forAll(sf, pointi) { sf[pointi] = pow(coord[pointi].x(), 0.6); } when the exponent is integer type e.g., 2 instead of 0.6, then it works. The problem is always when the exponent is scalar type or float type. Any advice? |
September 11, 2016, 09:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: My guess is that you have "x" values that are negative. For example:
pow(a,0.5) Code:
sqrt(a)
September 11, 2016, 10:36 |
SSSSS
Rep Power: 14 |
Yes, you are right. Thanks alot.
openfoam |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
