Solving PDE for a fictious time
Old   September 16, 2016, 09:37
Default Solving PDE for a fictious time
Abdallah Salem
abdo1984 is on a distinguished road
Hello dears
I have to solve a simple a PDE for an artificial time not physical time.
ddt(psi) + grad(psi) = signPsi
where signPsi is just the sign of psi
My attempt to do so is creating new time instant runTime1 which has the same value of runTime . when I reached the equation I did
runTime.setDeltaT(0) ;
fvMatrix psiEq(fvm::ddt(psi) + fvc::grad(psi) == signPsi ) ;
psiEq.solve() ;
Then I synthesized runTime with the phyiscal runTime1
Foam::Time& runTime(runTime1) ;
runTime.setDeltaT(runTime1.deltaTValue()) ;
but I got error message after few iterations
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::Time::adjustDeltaT() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at ~/OpenFOAM/abdo-2.3.0/application/solvers/multiphase/sclsvof10/solveLSE.H:32
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
in "/home/abdo/OpenFOAM/abdo-2.3.0/platforms/linux64GccDPOpt/bin/scLsVof10"
Any one has an idea to solve such a problem, I would be so thankful.
abdo1984 is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
