reactingMultiphaseEulerFoam: new alphat wall function
Prev Previous Post   Next Post Next
Old   January 16, 2017, 07:10
Default reactingMultiphaseEulerFoam: new alphat wall function
vigges is on a distinguished road
Hi folks,
I am having some problems with the reactingMultiphaseEulerFoam in OpenFOAM 3.0.0, more precisely, with the usage/implementation of compressible::alphatJayatillekeWallFunction.
Setup Description:
  1. simple 2D channel
  2. heated lower and upper walls
  3. initial phase conditions:
    • 50% Fluid A
    • 50% Fluid B
  4. inlet: 100% Fluid A
  5. alphat BC at walls: compressible::alphatJayatillekeWallFunction
  6. there is no mass transfer between phases, only momentum and heat transfer
Problem Description:
When I run the solver, I get the following error message
--> FOAM FATAL ERROR:
lookup of turbulenceProperties.fluidA from objectRegistry region0 successful
but it is not a compressibleTurbulenceModel, it is a kOmegaSST
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/xxx/OpenFOAM/OpenFOAM-3.0.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 181.
Questions
  1. Does anybody know, how to make that work or if it works in general?
Thank you for your help!
vigges is offline   Reply With Quote
multiphaseeulerfoam, reactingmultiphaseeulerf, thermal wall function
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
Radiation interface hinca CFX 15 January 26, 2014 17:11
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
