WENO Schemes for OpenFOAM v5
Like Tree7Likes
  • 2 Post By mAlletto
  • 1 Post By Zeppo
  • 3 Post By tiam
  • 1 Post By tiam
Old   July 19, 2019, 05:37
Default WENO Schemes for OpenFOAM v5
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
I am trying to apply WENO scheme that is build based on OpenFOAM v2.3 to OpenFOAM v5.
https://github.com/TobiasMartin/WENO...bWENOEXT-2.3.x
However, when i compile the new library I got error as shown in the attached figure.
It would be appreciate if could someone help me to fix this error.
Thanks and Best regards
ndtrong is offline   Reply With Quote
Old   July 20, 2019, 07:52
Michael Alletto
mAlletto will become famous soon enough
The definition of the factorial function changed from of 2.3 to 5. In 2.3 it takes a scalar as argument and returns a scalar. In 5 it takes a label (int) as argument and returns a label. So you have to change the function calls in the weno schemes accordingly.
ndtrong and vivek05 like this.
mAlletto is offline   Reply With Quote
Old   July 20, 2019, 14:50
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Your library runs this code:
Foam::scalar Foam::geometryWENO::Fac(scalar x)
	if (x <= 0) return 1.0;
	else
		return Foam::factorial(x);
It is
Foam::factorial(x)
that fails to compile.
There are 2 versions of overloaded function factorial in OpenFOAM, with function parameters being uLabel and label:
   54 Foam::uLabel Foam::factorial(uLabel n)
   55 {
   56     static uLabel factTable[13] =
   57     {
   58         1, 1, 2, 6, 24, 120, 720, 5040, 40320,
   59         362880, 3628800, 39916800, 479001600
   60     };
   61
   62     #ifdef FULLDEBUG
   63     if (n > 12)
   64     {
   65         FatalErrorInFunction
   66             << "n value out of range (> 12)"
   67             << abort(FatalError);
   68     }
   69     #endif
   70
   71     return factTable[n];
   63 Foam::label Foam::factorial(label n)
   64 {
   65     static label factTable[13] =
   66     {
   67         1, 1, 2, 6, 24, 120, 720, 5040, 40320,
   68         362880, 3628800, 39916800, 479001600
   69     };
   70
   71     #ifdef FULLDEBUG
   72     if (n > 12 && n < 0)
   73     {
   74         FatalErrorInFunction
   75             << "n value out of range"
   76             << abort(FatalError);
   77     }
   78     #endif
   79
   80     return factTable[n];
   81 }
Try this to see if it works
return Foam::factorial(static_cast<uLabel>(x));
ndtrong likes this.
Zeppo is offline   Reply With Quote
Old   July 20, 2019, 15:20
Timofey Mukha
tiam is on a distinguished road
Originally Posted by ndtrong View Post
Hi everyone,
I've been in contact with Tobias, the author of the library, and offered to upgrade the library so that it compiles across most version of OF and he agreed. I will get this done in the next month. That being said, I quickly patched the library to get it compiled on OFv1806, check the fork by timofeymukha on GitHub. The downside is that the tutorial crashed . I hope me and Tobias together can make things work.
louisgag, ndtrong and mAlletto like this.
tiam is offline   Reply With Quote
Old   July 23, 2019, 01:41
Nguyen Duy Trong
Thank you very much with your information.
Could you please share with me some update, I also would like to read to get more understanding OpenFOAM.
Old   November 18, 2019, 06:07
Timofey Mukha
Dear all,
I am happy to say that after me and Tobias having put in some work, the library should now work for modern OpenFOAM versions, both .org and .com. Please feel free to test it. I should say directly that any questions regarding the functionality are better directed at Tobias, since I've only helped with the version upgrade, but now little about how the code functions.
Best,
Timofey
mAlletto likes this.
Fundamental questions about numerical schemes Obad OpenFOAM Running, Solving & CFD 1 May 10, 2021 10:40
Transitional Flat Plate Simulation + WENO Schemes hxaxtma OpenFOAM 1 May 29, 2017 10:26
ENO and WENO schemes sachinsiitkgp Main CFD Forum 12 February 18, 2016 13:03
Sods problem: Oscillations with WENO schemes Ironiker System Analysis 0 May 31, 2015 16:57
ENO and WENO schemes HaKu Main CFD Forum 1 April 5, 2011 22:49
