fvOptions and Vector/Vectorfield in simpleFoam
Old   February 24, 2017, 10:02
Unhappy fvOptions and Vector/Vectorfield in simpleFoam
Andreas Müller
Andreas M. is on a distinguished road
i ran into an issue using fvOptions and since I haven't found any solution yet:
I want to use fvOptions in order to add a precalculated sourceterm to my UEqn.
Despite the examples i found yet, fvOptions should contain a vector/vectorfield, which are calculated in advance for the whole interior region.
Examplecode:
tmp<fvVectorMatrix> UEqn
        fvm::div(phi, U)
      + turbulence->divDevReff(U)
        fvOptions(U)
where "fvOptions(U)" is a (most likely) different vector for every cell.
Just adding the vector/vectorfield into the equation results into a Foam Fatal Error.
Im glad for every response.
Thanks in advance.
Im sorry for grammatical errors.
Andreas M. is offline   Reply With Quote
Old   February 24, 2017, 11:35
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
fvVectorMatrix UEqnLHS
    fvm::div(phi, U)
IOobject io
    "USource",
    U.instance(),
    U.mesh(),
    NO_READ,
    NO_WRITE,
    false
DimensionedVectorField USource
    io,
    U.mesh(),
    UEqnLHS.dimensions()/dimVolume;
forAll(USource, i)
    USource[i] = vector(i, 2*i, 3*i);
fvVectorMatrix UEqn
    UEqnLHS
 == USource
Zeppo is offline   Reply With Quote
