Flux across cyclicACMI coupled patches
Old   June 15, 2020, 09:31
Default Flux across cyclicACMI coupled patches
Joel C Lisanti
j.lisanti is on a distinguished road
I am developing an HLLCL solver for an application that requires a cyclicACMI interface.
I have attempted to develop this solver using an approach similar to rhoCentralFoam but believe I have run into this https://bugs.openfoam.org/view.php?id=2561 issue.
I have also attempted to use a similar approach to the dbnsTurboFoam solver included in foam-extend but run into a problem when looping across coupled faces.
The scalar field returned by p_.boundaryField()[patch index].patchInternalField() or p_.boundaryField()[patch index].patchNeighbourField() includes both coupled and uncoupled faces (with zero values). Is anyone familiar with the appropriate way to deal with this. I assume I need to loop over the coupled faces with appropriate weights (assuming multiple faces are coupled at the same time) and probably don't need to loop across each of the (4) boundary fields required for the cyclicACMI?
I am running openfoam-7.
Thank you for any assistance you may be able to provide.
j.lisanti is offline   Reply With Quote
coupled boundary, cyclicacmi, rhocentralfoam
Coupled patches for heat transfer RaghavendraRohith OpenFOAM Running, Solving & CFD 13 August 30, 2021 08:24
[mesh manipulation] mirrorMesh and undoing the joining of patches chegdan OpenFOAM Meshing & Mesh Conversion 3 October 21, 2015 08:09
[swak4Foam] and accessing flux on remote patches for setting B.C's mayank.dce2k7 OpenFOAM Community Contributions 19 August 21, 2013 19:01
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
