problem in writing a solver for a 3-step runge kutta(incompressible flow)
Old   February 24, 2014, 13:03
Default problem in writing a solver for a 3-step runge kutta(incompressible flow)
ooo
ooo is on a distinguished road
I'm implementing a 3-step runge kutta descritization for solving incompressible flow.
The results are completely wrong.
I would appreciate if you have a look at the code below and tell me if you see any problem :
while (runTime.loop())
 double alpha,gamma,zeta;
 volVectorField Unew(U), UOld2(U), UTmp(U) ;
 surfaceScalarField phiOld2(phi), phiTmp(phi);
 volScalarField pPhi(p);
        for (int i = 1 ;  i<=3 ; ++i)
            switch (i)
                case 1 : {UOld2=U ; phiOld2=phi ; alpha=4./15. ; gamma= 8./15. ; zeta =0.; break ; }
                case 2 : {UTmp=U ; phiTmp=phi ; alpha=1./15. ; gamma= 5./12. ; zeta =-17./60.; break ; }
                case 3 : {UOld2=UTmp ; phiOld2=phiTmp ; alpha=1./6. ; gamma= 3./4. ; zeta =-5./12.; break ; }
                default : break ;
        adjustPhi(phi, U, p);
        U = U + runTime.deltaT() *
         + 2*alpha*fvc::laplacian(nu,U)
         - 2*alpha*fvc::grad(p)
         - gamma*fvc::div(phi, U)
         - zeta*fvc::div(phiOld2, UOld2)
      solve(alpha*runTime.deltaT()*fvm::laplacian(nu,Unew) - fvm::Sp(1.,Unew)  == //(alpha*runTime.deltaT())  ==
      (-1.)*(U) + alpha*runTime.deltaT()*fvc::laplacian(nu,U) );
      solve (fvm::laplacian(pPhi) == fvc::div(U)/(2.*alpha*runTime.deltaT()));
      U =  Unew - (2.*alpha*runTime.deltaT()*fvc::grad(pPhi));
      p += pPhi - alpha*runTime.deltaT()*nu*(fvc::laplacian(pPhi));
         U.correctBoundaryConditions();
runTime.write();
ooo is offline   Reply With Quote
Old   March 4, 2014, 11:19
ooo
I make my code shorter, maybe someone has any idea regarding any problem on this kind of implementation :
      solve (fvm::laplacian(pPhi) == fvc::div(U)/(2.*alpha*runTime.deltaT()));// pPhi is a pseudo pressure without physical meaning
Old   April 4, 2017, 09:32
hua1015's Avatar
Hua
hua1015 is on a distinguished road
Dear Foamer,
Recently, I am interested in writing a solver for a 3-step runge kutta for incompressible flow and suffered some problem. Did you implemented it? Would you mind give me some suggestions?
hua1015 is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Maximum words supported by the flow solver exceeded rae CFX 3 June 6, 2013 06:49
Problem with changing mass flow rate roo FLUENT 3 June 4, 2013 14:53
On Setring Step Size in unsteady Solver of FLUENT lzgwhy FLUENT 0 August 19, 2009 22:44
