request for volScalarField k from objectRegistry region0 failed+(DPMFoam)
Like Tree11Likes
Old   April 21, 2017, 01:24
Default request for volScalarField k from objectRegistry region0 failed+(DPMFoam)
abdollahi
abdollahi is on a distinguished road
Hi Everyone,
I have a problem with my case solving by lagrangian(DPMFoam), which, I am presenting you in the following feedback information:
--> FOAM FATAL ERROR:
available objects of type volScalarField are
12
nut.H2O
k.H2O
(1|A(U.H2O))
kEpsilon:G
alpha.H2O_0
nu
div(phi.H2O)
p
rho.H2O
mu.H2O
alpha.H2O
epsilon.H2O
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/a/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:?
#3 Foam::turbulentMixingLengthDissipationRateInletFvP atchScalarField::updateCoeffs() at ??:?
#4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs() at ??:?
#5 Foam::RASModels::kEpsilon<Foam::PhaseIncompressibl eTurbulenceModel<Foam::singlePhaseTransportModel> >::correct() at ??:?
#6 ? at ??:?
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8 ? at ??:?
Aborted (core dumped)
Did anyone have the same problem before ? I mean, how to deal with error type : "request for volScalarField k from objectRegistry region0 failed" ?
I will be appreciate for any advice.
abdollahi is offline   Reply With Quote
Old   April 21, 2017, 05:04
Max
WildeCat is on a distinguished road
Hi abdollahi,
the error message you get tells you the solution. You are using "DPMFFoam" as a solver and a field called "k".
The next thing openfoam tells you is which fields are available
12
nut.H2O
k.H2O
(1|A(U.H2O))
kEpsilon:G
alpha.H2O_0
nu
div(phi.H2O)
p
rho.H2O
mu.H2O
alpha.H2O
epsilon.H2O
I imagine you have a field "k" in the "0" directory. This field should based on your error message be specified per species, so in your case "k.H2O".
You can check out the openfoam tutorial (I put the link for openfoam301) here
https://github.com/OpenFOAM/OpenFOAM.../Goldschmidt/0
where the velocity "U" is specified as "U.air".
Hope I was of help
Kummi, souza.emer and hashimh1994 like this.
WildeCat is offline   Reply With Quote
Old   April 21, 2017, 05:37
abdollahi
thanks
But I have in 0 dictionary U.H2O , k.H2O,…. . Fluid in my case is water.
Old   April 21, 2017, 05:40
Default More information
Max
Hi abdollahi
For me to help you more I need more information.
Would it be possible for you to upload a simplified version of your test case with the 0, constant and system directory?
Old   April 21, 2017, 06:34
abdollahi
I sent 0,constant and system dictionary as private message.
thank you very much
Old   April 21, 2017, 09:23
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
@abdollahi
Error is caused by turbulentMixingLengthDissipationRateInletFvPatchSc alarField. It uses TKE to calculate dissipation rate and by default in OpenFOAM TKE field is called k.
In you case it is called k.H2O, so in turbulentMixingLengthDissipationRateInlet description you have to add
k k.H2O;
so it becomes something like:
my-lovely-inlet
    type turbulentMixingLengthDissipationRateInlet;
    mixingLength 100;
    k k.H2O;
    value uniform 10;
alexeym is offline   Reply With Quote
Old   April 21, 2017, 11:43
abdollahi
Hi alexeym
I solve this case by simpleFoam as steady state, after it is converged, I replace the latest time in 0 dictionary in lagrangian (DPMFoam). I don’t understand what do you say? I don’t know where I put “ k .H2O” in simpleFoam or lagrangian? what dictionary?
thanks
Old   April 21, 2017, 13:20
Alexey Matveichev
Since the error happens during DPMFoam run, you have to add the line to 0 folder in DPMFoam case. And since turbulentMixingLengthDissipationRateInlet is BC for epsilon, you have to add the line to epsilon.H2O file. But since it you, who run simulations, you should know better.
Old   April 22, 2017, 00:01
abdollahi
hi,
"k" in 0 dictionary in simpleFoam:
| \\ / O peration | Version: 2.4.0 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1;
boundaryField
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.045;
value $internalField;
outlet
intensity 0.06;
U U;
walls
type kqRWallFunction;
value uniform 0;
bottom
value uniform 0;
back
type wedge;
front
type wedge;
stl
value uniform 0;
"k.H2O" in 0 dictionary in DPMFoam:
FoamFile
version 2.0;
format ascii;
location "1228";
object k;
internalField nonuniform List<scalar>
25179
3.15091e-06
2.56557e-06
2.0005e-06
1.37121e-06
7.18191e-07
4.0741e-07
Old   April 22, 2017, 00:07
abdollahi
"epsilon" in 0 dictionary in simpleFoam:
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 200;
boundaryField
inlet
mixingLength 0.15;
outlet
mixingLength 0.0025;
walls
type epsilonWallFunction;
bottom
back
type wedge;
front
type wedge;
stl
"epsilon.H2O" in 0 dictionary in DPMFoam:
FoamFile
version 2.0;
format ascii;
location "1228";
object epsilon;
25179
7.08276e-08
5.18813e-08
3.57445e-08
2.02775e-08
7.64593e-09
Old   April 22, 2017, 01:59
Alexey Matveichev
1. In dictionaries, you have posted, find the following sequence of letters:
2. Compare what you have around and what I have posted in post #6 (request for volScalarField k from objectRegistry region0 failed+(DPMFoam)).
3. Make corresponding corrections in the case, which halts with error.
Old   April 23, 2017, 10:07
abdollahi
thanks, I change it, but I have same error.
Old   April 23, 2017, 12:59
Alexey Matveichev
What changes did you made? Error is EXACTLY the same? It looks like WE have problems running the case, not you.
Any way, the only person in the thread, who saw you case files is WildeCat, let's wait for his answer.
Old   April 23, 2017, 15:07
Default Answer
  #14
Max
Hi all, I saw parts of the file and I agree, that the error is most likely from what you mention Alex. I send this as a pm to abdollahi. But I got the case as messages and couldnt run it myself. Could you upload the case on a fileshare? It would make things a hell of a lot easier for us to help you. Cheers
Old   April 24, 2017, 03:55
Default Solution
  #15
Max
I have received the full case and indeed Alex, what you suggested is the right solution. After correcting this error, also 2 others show up which have to be corrected in the same way.
For everybody having a similar problem I refer them to post #6 and
https://www.cfd-online.com/Forums/op...onditions.html
which presents how to restart a simulation with a different boundary condition
Best regards
Old   April 24, 2017, 08:30
abdollahi
hi
my case is run without error,I really appreciate your help.
Old   July 15, 2018, 04:16
Default yPlus
  #17
Ali Shayegh
amuzeshi is on a distinguished road
Hello Alex
my error is relatively the same; but mine is about yPlus. I'm using simpleFoam -postProcess -func yPlus. yPlus is generated only in 0 time but not in the next steps (case dir/postProcessing/yPlus). What's the problem? The error is as the following:
    request for volScalarField yPlus from objectRegistry region0 failed
5
nut
k
nu
p
epsilon
    From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
#3  Foam::functionObjects::yPlus::execute() at ??:?
amuzeshi is offline   Reply With Quote
Old   July 16, 2018, 03:07
Alexey Matveichev
Creating single postProcessing/yPlus/0/yPlus.dat file is normal yPlus function object behaviour. In this file data for all time steps are stored.
Describe your case in more details. yPlus function object runs on pitzDaily tutorial case quite OK: creates yPlus field for every available saves and collects statistics in postProcessing folder.
Old   July 16, 2018, 06:08
Ali Shayegh
This is a backward Facing Step case using k-w. Pls check if you could get yPlus using the method mentioned.
Old   July 16, 2018, 06:25
Alexey Matveichev
Everything was identical to pitzDaily tutorial. You case converged in 1198 iterations. simpleFoam -postProcess -func yPlus calculated y+ values without any problems.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
