A function can only be used in serial calculation not parallel calculation |
January 5, 2020, 18:25 |
hui cheng
Rep Power: 8 |
Hi everyone,
I have met a strange problem with my OpenFOAM solver when doing a parallel calculation. This problem only comes out when I run the solver parallelly. My solver is developed based on the original pisoFoam. At each timestep, I using Nettings.updateVelocity(U, mesh) to get the fluid velocities at specific positions (the positions is changeable at each timestep). You can see the code in my main solver here: Code:
while (runTime.loop()) { Info << "Time = " << runTime.timeName() << nl << endl; #include "CourantNo.H" // Pressure-velocity PISO corrector { #include "UEqn.H" // --- PISO loop while (piso.correct()) { #include "pEqn.H" } } laminarTransport.correct(); turbulence->correct(); //>>>>>>>>>>>>>Below>>>>>>> Nettings.updateVelocity(U,mesh); //<<<<<<<<<<<<<Above<<<<<< runTime.write(); Info << "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info << "End\n" << endl; return 0; } Code:
void Foam::netPanel::updateVelocity( const volVectorField &U, const fvMesh &mesh) { const vectorField ¢res(mesh.C()); List<vector> fluidVelocities(structuralElements_memb.size(), vector::zero); Info << "In updateVelocity, number of mesh is " << centres.size() << endl; Info << "In updateVelocity, number of U is " << U.size() << endl; scalar maxDistance(1); forAll(EPcenter, Elemi) { maxDistance = 1; vector nearestCell(vector::zero); scalar loops(0); forAll(centres, cellI) // loop through all the cells, { scalar k1(calcDist(centres[cellI], EPcenter[Elemi])); if (k1 < maxDistance) { maxDistance = k1; fluidVelocities[Elemi] = U[cellI]; nearestCell = centres[cellI]; loops += 1; Info << "After " << loops << " times of loop, the nearest cell is " << nearestCell << "to point " << EPcenter << "\n" << endl; } } } fluidVelocity_memb = fluidVelocities; // only assige onece Info << "the velocity on nodes are " << fluidVelocity_memb << endl; } Code:
serial run Starting time loop Time = 0.01 Courant Number mean: 0.000565 max: 0.0904 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 2.4007e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.891308, Final residual = 1.23902e-06, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.895257, Final residual = 1.31102e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 8.40918e-07, No Iterations 35 time step continuity errors : sum local = 9.50237e-10, global = 1.27782e-10, cumulative = 1.27782e-10 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.00445555, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.004493, No Iterations 1 In updateVelocity, number of mesh is 184320 In updateVelocity, number of U is 184320 After 1 times of loop, the nearest cell is (-0.49375 -0.21875 -0.39375)to point (0 0.05 -0.1) ... ... After 45 times of loop, the nearest cell is (-0.00625 0.05625 -0.20625)to point (0 0.05 -0.2) the velocity on nodes are 4((0.226059 -2.8946e-08 -3.59708e-08) (0.226059 3.97379e-08 -4.07855e-08) (0.226059 2.65165e-08 -2.22689e-08) (0.226059 -4.12251e-08 -1.8172e-08)) ExecutionTime = 2.31 s ClockTime = 2 s Code:
MPIRUN Starting time loop Time = 0.01 Current Number means: 0.000565 max: 0.0904 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 2.4007e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.892185, Final residual = 1.24606e-06, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.895991, Final residual = 1.31577e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 9.93486e-07, No Iterations 34 time step continuity errors : sum local = 1.12264e-09, global = -1.18173e-10, cumulative = -1.18173e-10 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0107252, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0106817, No Iterations 1 In updateVelocity, number of mesh is 23177 In updateVelocity, number of U is 23177 the velocity on nodes are 4{(0 0 0)} ExecutionTime = 0.57 s ClockTime = 1 s In the parallel calculation, I used scotch method to decompose the calculation domain into 8 subdomains. One should notice that the "updateVelocity" function can output the number of mesh at the beginning.
The question is that how can I run this solver parallelly? Because the position might sit in any subdomain, my "updateVelocity" can not return the correct velocity. Do I need to reconstruct all the subdomains at each timestep to fulfil this functionality? Best regards, |
January 7, 2020, 12:18 |
Joachim Herb
Rep Power: 21 |
If you run in parallel, each process runs with its own mesh and cannot see the rest of the mesh. If you need to access information from other processes you probably must use something like scatter/gather. Also there are some macros like gSum, gAverage, ... which does reducing information between processes automatically.
The reason, you only see one output (actually from process 0) is that Info statements are only put out from this process and hidden from the rest. If you want to see all processes, use cout. (or perhaps Perr) See https://github.com/OpenFOAM/OpenFOAM...est-parallel.C |
fsi |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
