How to make a mapper that takes nearest vertex instead of interpolating?
Old   April 25, 2017, 05:10
Default How to make a mapper that takes nearest vertex instead of interpolating?
Lukas Lebovitz
lukas.lebo is on a distinguished road
Hi Foamers
I'm modifying an InletGenerator that currently uses a mapper to interpolate values from a virtual Grid onto the mesh at the inlet.
// mapper is created like this for mapping Virtual Field to Patch Field
mapperVP_Ptr_.reset
        new pointToPointPlanarInterpolation
            virtualGridPoints_,
            this->patch().patch().faceCentres(),
            perturb_
// it is used like this
uFluctFiltered = mapperVP_Ptr_().interpolate(virtualFilteredField_);
Is there any simple change I can make so it will just take the value of the nearest virtualGridPoint to map onto the patch instead of interpolating?
Thanks so much!
lukas.lebo is offline   Reply With Quote
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 16:45
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 14:14
