Make wall-function read a newly defined field inside modified kEpsilon model
Like Tree1Likes
  • 1 Post By usv001
Old   June 28, 2017, 23:29
Default Make wall-function read a newly defined field inside modified kEpsilon model
William Corrêa Radünz
Radunz is on a distinguished road
Greetings everyone,
I have been working on a modified kEpsilon model for wind flow modeling and it was necessary to redefine the once constant Cmu and as height-dependent field i.e. a volScalarField. I have also created it as an IObject to plot it along with the remaining fields and all works fine. The problems begin now. It just so happens that epsilonWallFunction and nutkRoughWallFunction depend on Cmu and as such the must access the modified kEpsilon height-dependent Cmu, which I will name after Cmu(z). I am well aware that the wall functions are general and thus have no information about the selected turbulence model so they access turbulence fields through their base class turbulenceModel.H through this lines, as example (turbulence kinectic energy, viscosity and turbulent viscosity fields):
@epsilonWallFunction
const tmp<volScalarField> tk = turbulence.k();
const volScalarField& k = tk();
const tmp<scalarField> tnuw = turbulence.nu(patchi);
const scalarField& nuw = tnuw();
const tmp<scalarField> tnutw = turbulence.nut(patchi);
const scalarField& nutw = tnutw();
However, when I try to access the newly created Cmu(z) through this
const tmp<volScalarField> tCmuw = turbulence.CmuZ();
The compiler complains saying basically that "error: ‘const class Foam::turbulenceModel’ has no member named ‘CmuZ’". This is attached as "log.withoutTurbulenceModel". So what have I done? I realized the call above led to the base class turbulenceModel so I declared CmuZ as a virtual function there.
@turbulenceModel.H
virtual tmp<volScalarField> CmuZ() const = 0;
When I compile, I get more issues. In my view, the issue is that somehow turbulenceModel's derived classes (turbulence models) are scanned after the CmuZ() field which is only implemented in kEpsilon model through run-time selection tables. There are some lines as
"error: cannot allocate an object of abstract type ‘Foam::incompressible::RASModels::qZeta’
return autoPtr<baseType>(new baseType##Type parList); \
../turbulenceModels/lnInclude/RASModel.H:111:9: note: in expansion of macro ‘declareRunTimeSelectionTable’"
and that's when I get lost. I've been trying so solve this for two weeks, read about polymorphism and so on but stagnated.
Best regards.
Radunz is offline   Reply With Quote
Old   July 1, 2017, 00:54
usv001 is on a distinguished road
Hi there,
You are correct that the "cannot allocate an object of abstract type" error occurs because you are trying to a create an object which has a pure virtual function, i.e. one which ends with '= 0'. I think that means that each of the derived class is required to provide an implementation of the CmuZ() which is not what you want to do.
Try writing the function body of the CmuZ() function in turbulenceModel.H to return a tmp<volScalarField> with the some dummy Cmu value like 0.09.
    return
        new volScalarField
            volScalarField
                IOobject("Cmu", ...),
                mesh,
                dimensionedScalar("dummy", dimless, 0.09)
Then, you may specialize this function in your own custom turbulence model. Now, you should be able to access this function from the wall function classes. I am not sure if this will work for certain but please give it a try and let everyone know of the result.
An even more straightforward way could be to access the Cmu volScalarField by looking up the object from its object registry, e.g.
const volScalarField& Cmu = mesh.lookupObject<volScalarField>("Cmu");
Cheers,
USV
Radunz likes this.
usv001 is offline   Reply With Quote
Old   July 18, 2017, 22:39
Originally Posted by usv001 View Post
Hi there,
    return
        new volScalarField
            volScalarField
                mesh,
Cheers,
USV
Thank you very much. The piece of code
indeed solved my problems.
runtimeselection, turbulence, wallfunction
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
