Accessing velocity at inverse position
Old   June 30, 2017, 08:13
Default Accessing velocity at inverse position
fusionfire21 is on a distinguished road
Hi guys,
I am trying to implement the following formula into my code:
\vec{v}_a = \frac{1}{2}(\vec{v}(\vec{r})+\vec{v}(-\vec{r}))
That is, I aim at calculating this "antisymmetric" velocity for every time step.
How can I implement especially the \vec{v}(-\vec{r}) part, i.e. the access to the velocity at the inverse position?
Of course, \vec{v}(\vec{r}) is simply implemented as
volVectorField U
Thank you very much in advance!
Regards
fusionfire
fusionfire21 is offline   Reply With Quote
Old   June 30, 2017, 23:41
usv001 is on a distinguished road
Hi there,
What is your domain and mesh like? On the top of my head, I cannot think of a way to access velocity at the inverse location unless the mesh is a uniform structured Cartesian or cylindrical one.
USV
usv001 is offline   Reply With Quote
Old   July 1, 2017, 03:11
the domain is an ellipsoid with its center at the origin, generated with a rather complicated snappyHexMesh file. The coordinate system is cartesian though.
Regards
Old   July 1, 2017, 03:24
If your mesh is symmetrical about the origin, then perhaps you could build a volScalarField whose internalField consists of the indices of the cells centered at the corresponding inverse locations. Then, you could simply loop over the internalField to get your \vec{v_a}. If you do it carefully, you only need to loop over half the internalField since the values should be symmetric. But you must first build the volScalarField somehow.
Can you attach an image of your mesh? That could give others some ideas.
USV
Old   July 1, 2017, 03:28
Actually, if you mesh only the first octant and then mirror mesh to get the full mesh, you would get a symmetrical mesh about the origin. Then, the cell index at the inverse location could probably be obtained by adding a constant number to the cell index in the first four octants where z (or x or y) is positive.
USV
coordinates, position, velocity, volvectorfield
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 06:15
Accessing Velocity Components anfho OpenFOAM Programming & Development 1 June 30, 2011 19:21
accessing another velocity field in bc daviderzen OpenFOAM 0 April 20, 2011 06:24
Plot velocity profile at different position AirS Main CFD Forum 2 December 3, 2010 06:03
