July 13, 2017, 17:08 |
Writing the following equation
Achuth Nair Balachandran Nair
Rep Power: 9 |
I am working with multiphase flow through a porous medium and I am implementing the temperature equation. I have a doubt regarding how the following convection term needs to be implemented. (rho*cp) * u * del(T) How I have implemented it is: rhocf * fvm::div(Uf,T) where Uf = fvc::interpolate(U) & mesh.Sf(); Is it right? Or should I take the temperature field as a fvc::grad(T) to be precise. I would really appreciate the help! |
July 14, 2017, 04:23 |
Rep Power: 11 |
I don't know exactly your meaning of del(T).
I guess you want to implement the advection of your temperature-field, right? This would mean for constant density and heat capacity your equation reads: dT/dt = -divergence(u*T) as differential equation. Most of the time divergence(u) = 0. Therefore you will see dT/dt = -u*gradient(T) most of the time, but the equation above is more generall. Therfore you need fvc:: (Uf*T_face) for explicit or fvm:: (Uf,T) for implicit discretisation (and fvm::ddt(T)). I hope this was usefull for you. |
July 14, 2017, 17:40 |
Cyprien
Rep Power: 18 |
See this presentation pages 84 to 93. See also pages 100 to 108 for a 2 temperatures model.
Cheers, Cyprien |
Derivation of the Temperature Equation | Tobi | OpenFOAM Programming & Development | 21 | April 10, 2018 22:15 |
Writing an equation of state | FAKHREDDINE | CFX | 2 | April 3, 2017 12:08 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
Basic question about writing a differential equation related to finite element | RbBb | Main CFD Forum | 1 | April 10, 2014 03:50 |
How to? Extra term in k-e equation. Implicit-Explicit | be_inspired | OpenFOAM Programming & Development | 1 | March 19, 2013 10:50 |
