Different boundary condition for different scalar fields |
August 21, 2017, 16:37 |
Andy
Rep Power: 10 |
I have two temperature fields, a solid temperature T_s and a fluid temperature T_f. These are created as two separate volScalarFields, modelling a flow though packed spheres between parallel plates, the upper wall is heated with a constant heat flux and the lower wall is adiabatic. I am just solving a scalar transport equation for both temperatures. I set the temperature of the fluid T_f = 300K at the inlet. My reference says to set the solid temperature T_s = T_f at the upper wall of the parallel plates where the constant heat flux condition is located. For the constant heat flux condition at the upper wall I need to set the gradient of the fluid temperature dT_f/dy = q/k. T_f at the wall is not known in advance and must be computed as part of the solution. Once it is known, I need to set T_s = T_f at the upper wall. I have set fixedGradient at the upper wall, which works for the fluid temperature, but I wondered how use a separate boundary condition for the solid temperature at the upper wall? Thanks in advance for any help, A. |
boundary conditon, gradient, heat flux., scalar field |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
