error encountered when compiling modified solver |
September 16, 2017, 03:22 |
jawfi
Rep Power: 8 |
Hey guys,
I getting an error when I try to compile a modified solver. The error I am getting when putting the command wmake is : make: *** No rule to make target 'Make/linux64GccDPInt32Opt/myComponentFoam.C.dep', needed by 'Make/linux64GccDPInt32Opt/myComponentFoam.o'. Stop. All what I did is copying a interForm solver in my working directory and modifying Make/file with the new name and changing the source code to my new solver name The Make/files myComponentFoam.C EXE = $(FOAM_USER_APPBIN)/myComponentFoam my solver source file is called myComponentFoam.C I tried to remove old .dep files using the command wclean and rm -rf linuxGccDP0pt.... but that didn't fix the error. something to mention, I am using windows 10, not sure if that is causing the issue Please help if you have an idea of how to resolve this issue ? Thanks ! |
compile problems, compile solver, wmake error |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
error in compiling modified pisoFoam | sinatahmooresi | OpenFOAM Programming & Development | 2 | April 18, 2016 04:02 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
