Segmentation Fault error after min-max
Like Tree4Likes
  • 2 Post By floquation
  • 1 Post By Sugajen
  • 1 Post By PVERMA
Old   December 19, 2014, 07:52
Default Segmentation Fault error after min-max
Bharat Bhushan Sharma
bharat.gmail is on a distinguished road
Hello Dear Foamers,
I have been writing one of my solver and am stucked at one place due to segmentation fault error. Given below are the details about this error.
boundaryField
    adiabatic
        type            zeroGradient;
    heater
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    frontAndBack
        type            empty;
DILUPBiCG:  Solving for H, Initial residual = 1, Final residual = 1.75168e-16, No Iterations 1
Enthalpy  Min(H) = -2.5054e+23 Max(H) = 5.6046e+36
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::relativePermeabilityModels::krBrooksAndCorey::correct() in "/root/OpenFOAM/root-2.3.0/platforms/linux64GccDPOpt/lib/libporousModels.so"
 in "/root/OpenFOAM/root-2.3.0/platforms/linux64GccDPOpt/bin/impesFoam"
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
The location mentioned in above error stack is :
                forAll(H_,i)
                    if( ( H_[i] > -ROL_.value()*(scalar(2)*hvsat_.value() - hlsat_.value()) ) && ( (H_[i] < -ROV_.value()*hvsat_.value()) || (H_[i] == -ROV_.value()*hvsat_.value()) ) )
                        T_[i] = TSAT_.value();
                        dTdH_[i] = scalar(0.0);
                        Sb_[i] = - ( H_[i] + ROV_.value()*hvsat_.value() )/( ROL_.value()*hlg_.value() + (ROL_.value() - ROV_.value())*hvsat_.value() );
This piece of code is written inside krBrooksAndCarey.H which contains a derived class called krBrooksAndCarey. This is derived from a base abstract class wherein this H_ is declared as a volScalarField using following:
volScalarField H_
Also the H volscalarField which is a primitive variable for enthalpy equation is declared in createFields.H file as:
volScalarField H
IOobject
"H",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
I think there is something wrong with H volScalarField. I think there is no connection b/w H_ and H defined separately. I wish them to be representing same field variable. But dont know how to do so.
Can someone help me sortout this problem. I am really stucked.
Bharat
bharat.gmail is offline   Reply With Quote
Old   December 19, 2014, 08:41
Likun
Likun is on a distinguished road
Send a message via Skype™ to Likun
Hi Bharat,
Just an idea, please make sure that all the variables are properly initialized, sometimes that gives a Segmentation Fault error.
Best,
Likun
Likun is offline   Reply With Quote
Old   December 20, 2014, 00:36
T. Chourushi
Tushar@cfd is on a distinguished road
Hi all,
I agree with Likun, check the initialization of the variables. I think your solver is not able to initialize the variable (in your custom BC) which leads to the segmentation fault. I am not expert on custom BC, anyways I think the error could be in this formulation:
  forAll(H_,i)  {......}
As, a suggestion I would suggest you to try something like this....
  forAll(H_.BoundaryField(),i)  {......}
Also set the required internalField for the BC in you case directory. Wish you Best Luck
Best Regards!
Tushar@cfd is offline   Reply With Quote
Old   December 24, 2014, 02:31
Question
can the error be due to values out of bound as is printed below ?
Can some one tell me what is the maximum and minimum numerical value supported by openFoam in double or single precision ?
Old   December 24, 2014, 08:30
problem solved....
Old   August 2, 2017, 18:13
Sugajen
Sugajen is on a distinguished road
Hi all,
I have a similar problem. When I initialize a 3D array and run it for n=128, it crashes with Segmentation fault. The exact line where this happens is
double array[n+2][n+2][n+2];
The code does not throw an error during its compilation. But when running on a case, the error pops up. Also for smaller values of n (64, 32, 16...) it works fine. What could be the problem?
Thanks,
Sugajen
Sugajen is offline   Reply With Quote
Old   August 7, 2017, 03:53
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Originally Posted by Sugajen View Post
Hi all,
Thanks,
Sugajen
https://stackoverflow.com/questions/...ge-array-sizes
Ebrahim and Sugajen like this.
floquation is offline   Reply With Quote
Old   August 7, 2017, 14:30
Sugajen
Hi all,
I solved my problem using the following way of dynamically allocating a 3D array so that the heap memory is used. If we do a declaration as I had done on my original post, the stack memory will be used which has some memory limitations that could cause segmentation error.
double ***array = new double**[n+2];
for (int i = 0; i < n+2; i++)
    array[i] = new double*[n+2];
    for (int j = 0; j < n+2; j++)
    array[i][j] = new double[n+2];
Also, if we use heap memory, we need to explicitly release the memory later, as shown below.
for(int i = 0; i < n+2; ++i)
    for(int j = 0; j < n+2; ++j)
	delete[] array[i][j];
    delete[] array[i];
best,
Sugajen
Ebrahim likes this.
Old   September 18, 2017, 07:37
Default sigsegv error
Pooja Verma
PVERMA is on a distinguished road
Originally Posted by bharat.gmail View Post
problem solved....
how was the error solved.Iam having the same type of error.
parthigcar likes this.
PVERMA is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
