How to find the cell distance from a patch in openfoam?
Like Tree1Likes
  • 1 Post By Zhiheng Wang
Old   September 23, 2017, 10:26
Default How to find the cell distance from a patch in openfoam?
Phanindra
phani45 is on a distinguished road
Hi foamers,
can any one of tell me how can we find the distance between an internal cell from an inlet in openfoam
I need to use it as part of my code not as post processing
Regards,
Phanindra
phani45 is offline   Reply With Quote
Old   September 23, 2017, 17:06
Zhiheng Wang
Zhiheng Wang is on a distinguished road
label patchID = mesh.boundaryMesh().findPatchID("name of your patch");
labelList InternalFieldNextToPatch = mesh.boundaryMesh()[patchID].faceCells(); //// Gives List of cell IDs label next to patch//////
DynamicList<vector> Distance(0); /// distace betwen face center of patch and cell center of cell next to patch
if ( InternalFieldNextToPatch.size() == mesh.boundaryMesh()[patchID].size() )
// check weather patch size and list of cell ids is same or not/// this code may or may not work after usting refinemesh /////
forAll(InternalFieldNextToPatch, I)
Distance.append(mesh.C()[InternalFieldNextToPatch[I]] - mesh.Cf().boundaryField()[patchID][I]
save in some distance.H n include or you can also use
OR use
scalarField Dis = 1.0/mesh.deltaCoeffs().boundaryField()[patchID];
If you are using 4.z, plus or 5.x version at place of boundaryField() use boundaryFieldRef() I hope I did not do any typing mistake in code
Kummi likes this.
Zhiheng Wang is offline   Reply With Quote
Old   September 24, 2017, 07:00
Default Thank you Wang
Phanindra
Does the procedure works even for the internal cells and boundary patch distance?
Old   September 25, 2017, 02:57
Zhiheng Wang
Yes mesh.deltaCoeffs()[patchID] will give inverse of distance between boundary face n cell center. If you want
Distance between two internal Fields use [cellIDs] if you do not know cellIDs use the code I wrote.
Old   September 25, 2017, 08:00
Default Hi
Phanindra
Thanks . I will give it a try
Find distance from a cell to a Boundary patch oehmu OpenFOAM Programming & Development 1 March 22, 2016 23:47
interFoam running blowing up sandy13 OpenFOAM Running, Solving & CFD 2 May 5, 2015 07:16
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
How to find the flux through each cell in a each boundary patch? Hale OpenFOAM Pre-Processing 0 September 13, 2013 08:52
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
