Scalar Transport with Adaptive Meshing
Like Tree1Likes
  • 1 Post By emrahh
Old   October 4, 2017, 16:18
Default Scalar Transport with Adaptive Meshing
emrah
emrahh is on a distinguished road
I am trying to learn adaptive meshing capabilities of OpenFOAM to use it for a level set solver. For this reason, i modified the already available scalarTransportFoam solver to handle adaptive meshing. I solved a case where a circular region travels diagonally in a square region. I used a 100x100 mesh with no adaptation and same mesh with adaptation. When i compare the results of these cases, adaptive meshing seems to make the result worse although it increases computational time 20 times. I uploaded my cases and results. If you have some experience with adaptive meshing in OpenFOAM, could you please check my code if there is anything wrong with it?
Thanks in advance.
Regards, Emrah.
francescomarra likes this.
emrahh is offline   Reply With Quote
adaptive meshing clifford bradford Main CFD Forum 14 September 3, 2022 19:13
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Solving N (Non-Coupled) Scalar Transport Equations joel.lehikoinen OpenFOAM Programming & Development 9 October 3, 2013 08:00
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
transport equation for SGS scalar variance chinthakindi Main CFD Forum 0 April 27, 2004 09:26
