parasitic currents
Like Tree50Likes
Old   October 30, 2009, 10:58
Default parasitic currents
Robert Castilla
rcastilla is on a distinguished road
I have working with high weber number flows (capillary flows) and I am finding som important parasitic currents in the interface.
I have read that Brackbill (1992) J. Comput. Phys. 100 335-354, suggested to weight the surface tension force with the density in the cell in order to reduce this non-real currents.
I have modified this term in interFoam,
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
multiplying by
fvc::interpolate(rho/(twoPhaseProperties.rho1()-twoPhaseProperties.r
ho2())
The parasitic currents have been appreciably reduced. I am surprised than I so simple thing has not been before implemented in interFoam. Maybe there is some drawback that I don't know?
Best regards
kmou likes this.
rcastilla is offline   Reply With Quote
Old   October 30, 2009, 11:20
Suresh kumar Kannan
kumar is on a distinguished road
Hello Robert,
I agree with you, that we need a new thread for this discussion.
I have a basic question, how do you usually visualize or calculate your parasitic flows at the interface. do you do this by just performing some post processing or is there any script based on some literature to calculate this. I need to know this because I am running some lesinterfoam calculations and it is really important for me to resolve the forces properly at the interface.
I am using OF-1.5, and if the implementation that you did is specified in some literature you can also let me know the paper, I will look in to it.
I may also change the lesInterfoam solver and see if there is any major difference.
But first of all i want to know how to find out if there are any currents acting at my interface,
Hope you dont mind my basic question. I am new to the field of Multiphase flows. My Master thesis was in Incompressible flows, so i dont have much knowledge of Multiphase flows.
bye
with regards
K.Suresh kumar
kumar is offline   Reply With Quote
Old   October 31, 2009, 07:01
jaswi is on a distinguished road
Hi Robert
Thanks for sharing this information. I have been hvaing some similar issues with the parasitic currents. Please post some pictures showing the comparison.
According to you post:
multiplying by
ho2())
Does that means that your final expression in pEqn.H for phi now lokks like this:
phi = phiU +
fvc::interpolate(interface.sigmaK())*fvc::snGrad(g amma)*
fvc::interpolate(
rho / (twoPhaseProperties.rho1()
-twoPhaseProperties.rho2()
- ghf*fvc::snGrad(rho)
)*rUAf*mesh.magSf();
Thanks once again for sharing the information.
Best Regards
jaswi
jaswi is offline   Reply With Quote
Old   November 4, 2009, 09:12
Robert Castilla
kumar, the paper by Brackbill is, as far as I know, the first on parasitic currents. You can read also Harvie et al. Applied Mathematical Modelling, 30 (2006) 1056-1066.
jaswi, not exactly, since I am using OF 1.6 and ghf is no more used. The modified pEqn.H is as follows:
phi = phiU +
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)*
ho2()))*mesh.magSf()
+ fvc::interpolate(rho)*(g & mesh.Sf())
)*rUAf;
Attached you can see the velocity vectors of one experiment, made with paraview. In the right side, with density correction, the parasitic currents have been appreciably reduced.
Hope it can help you.
with regards
Robert
Old   November 4, 2009, 12:26
Dear Robert
Thanks for the answer and the pictures.
They do show a substantial decrease in the spurious currents.
I just can't wait to try that for my case :-)
BR
jaswi
Old   February 28, 2010, 19:50
Denis Semyonov
sundaero is on a distinguished road
multiplying by
ho2())
Thank you, Robert. This one was a really important notice (why I did not found it out by myself?). I am also dealing with low Capillary number flows and my OF model is suffering from high unphysical velocities close to interface. I will try modified model and see what would be the difference in my case.
One drawback here is that now it will take more time to compute. How much? That is an another question.
By the way, am I right that you did changes both in pEqn.H and UEqn.H ?
BR
Denis
sundaero is offline   Reply With Quote
Old   March 1, 2010, 10:09
Robert Castilla
Hi, Denis,
actually I have only modified the pEqn.H, since the Ueqn.H is only calculated if momentumPredicor is "true", which is not normally the case.
Hope it will be useful for you.
Best regards
Robert
Old   March 1, 2010, 10:24
Denis Semyonov
I got your point. But to be on a safe side I modified both.
Ok, I got some intermediate results. It seems that such a simple modification completely cured that annoying effect when there is unwanted high velocities near the interface and now my OF model is much better follow the experimental data.
Thank you, Robert one more time for posting this idea here.
I do not know how, but I think this idea should be somehow more widely known, because, I think, a lot of people deal with capillary flows and might face the similar problem.
kmou likes this.
Old   March 4, 2010, 17:21
Default has anybody applied this method for static problems?
Ali Q Raeini
aliqasemi is on a distinguished road
today, I made similar changes to interFoam, but it seems that it produces higher parasitic currents in my case which is kind of calculating capillary pressure in a bubble trapped in a closed micro-scale 2D shape with some convex edges (all boundaries are no-flow ->static problem). it seems that the term "fvc::interpolate(rho/(twoPhaseProperties.rho1()-twoPhaseProperties.rho2())" is greater than one and it causes higher surface tension force, and higher parasitic currents in my static problem.
has anybody applied this method for similar static problems?
rasool_soofi likes this.
aliqasemi is offline   Reply With Quote
Old   March 5, 2010, 11:07
Robert Castilla
I have mistyped the term. The suggestion of Brackbill is rho/<rho>, i.e.,
fvc::interpolate(2*rho/(twoPhaseProperties.rho1()+twoPhaseProperties.rho2 ())
This term has to be 1 in the interphase, and it has to reduce the force in the lighter phase. It can be greater than one in the heavier phase, but it should not increase the parasitic currents.
Robert
hwangpo, amir_kb and rasool_soofi like this.
Old   March 16, 2010, 03:09
Denis Semyonov
Thanks for the corrections.
It is noticeable that the previous version also worked fine for the gas-liquid flow as it has value of 1 in the heavier phase and at the interface and a very small value in the lighter phase.
Old   April 19, 2010, 11:56
Jens Klostermann
jens_klostermann is on a distinguished road
Hi all,
I made the same modifications to a 2D static bubble problem with the result, that an original round bubble gets octagonal!! So the results get worse! Right now we performing some systematic test.
The parasitic current problem is not that simple, since they depend on the physical problem (density ratio, viscosity ratio, We, Re, ...) and the numerical implementation of the VoF method.
Regards Jens
jens_klostermann is offline   Reply With Quote
Old   March 9, 2011, 11:15
Illya Shevchuk
linch is on a distinguished road
Hi Jens,
since one year passed, do you have any results of you investigation to share?
Best Regards,
Ilya
linch is offline   Reply With Quote
Old   June 24, 2011, 08:53
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
i also made the same modification in pEqn.H, but i still get very high spurious velocity at the interface. if you remember, since one year passed, coul you please post your fvScheme and fvSolution. and what were the properties of your fluids?
to have a look at my problem you can read here: http://www.cfd-online.com/Forums/ope...tml#post308969
Thanks
andrea
Andrea_85 is offline   Reply With Quote
Old   February 20, 2012, 10:42
Ivo
Ivooo is on a distinguished road
thanks for posting this. I implemented the change in OpenFOAM 2.1.0, but it seems to have no effect here.
As a benchmark, I am using a sessile droplet (d = 1mm, semi-sphere) on a flat plate. After settling down due to the distortions caused by the initialisation of the alpha1 phase on the rectangular mesh (about 0.03s), the drop starts to move around over the plate. I suspect this behaviour is due to spurious currents, which I hoped to prevent with the measures described above.
I will try to verify this result once more.
Ivooo is offline   Reply With Quote
Old   April 23, 2012, 12:36
Ali Q Raeini
We have solved the problem of spurious currents in our modified version of interFoam code, you can find the details in a paper (two-phase flow at low capillary numbers / small scales) being published in JCP:
http://dx.doi.org/10.1016/j.jcp.2012.04.011
The Sharp Surafce Force part, described in the paper, is a one line code which any one can easily implement. Smoothing and filtering are also proposed in the paper.
The paper is written for Cartesian meshes, but most parts are general, and now we are using the code for unstructured meshes with very few modifications / change of discretization algorithms. Hopefully these modifications will be published soon as well.
Old   April 23, 2012, 13:26
Pablo
pablodecastillo is on a distinguished road
Can you send me the paper to pablodecastillo at gmail dot com or give here a few hints??
Thanks
pablodecastillo is offline   Reply With Quote
Old   April 23, 2012, 15:02
Ali Q Raeini
Thanks
As a quick reply, the Sharp(er) Surface Force(SSF) formulation is as follows:
in interFoam/pEqn.H change
fvc::snGrad(alpha1)
to
fvc::snGrad( (1.0/(1.0-2.0*C)) * min( max(alpha1,C), (1.0-C) ) )
For Static cases use C=0.47-0.49, for dynamic simulations (moving interfaces) use C=0.15-0.20, roughly speaking. (the definition of C here is different from the paper)
Filtering is as important as sharpening the capillary force but it has a long story. I will be back to you later by email.
Old   April 23, 2012, 16:52
Pablo
Thanks Ali,
I will try tomorrow morning, and i will coment to you how it goes.
Old   April 24, 2012, 05:46
akidess's Avatar
Anton Kidess
You linked to your email instead of doi.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
capillary flows, interfoam, parasitic currents
how to monitor free surface elevation vs time in OF? ozgur OpenFOAM Post-Processing 56 September 14, 2015 08:11
parasitic currents Pei-Ying Hsieh Main CFD Forum 0 January 13, 2009 19:58
Parasitic currents reduction hsieh OpenFOAM Running, Solving & CFD 0 January 13, 2009 15:44
Parasitic currents reduction hsieh OpenFOAM Running, Solving & CFD 0 January 13, 2009 15:37
Modelling ocean currents of the past Earth pgm Main CFD Forum 3 March 2, 2005 08:45
