Hi,I have a question about momentum equation in interFoam
Like Tree3Likes
  • 1 Post By fumiya
  • 1 Post By santiagomarquezd
  • 1 Post By Tobi
Old   January 11, 2013, 09:19
Question Hi,I have a question about momentum equation in interFoam
anonymous
shchao is on a distinguished road
Dear Foamers:
I have read Henrik Rusche's phd thesis.Now i meet a question in the momentum equation of interFoam. Mr. Rusche defined an 'H' operator AH=As-An*phi where 'As' means source vector.Does As include the item like -grad(p)-g*x*grad(rho)...?Or What included in As?Thank you very much!
shchao is offline   Reply With Quote
Old   January 13, 2013, 05:59
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Take a look at the interFoam/UEqn.H:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
        sources(rho, U)
In the case of UEqn.H(), 'H' operator is constructed from the above
fvVectorMatrix UEqn. In the above definition of UEqn, there is no
terms corresponding to grad(p) and g*x*grad(rho), so these terms
are not included in the H operator in the interFoam solver.
Fumiya
fumiya is offline   Reply With Quote
Old   January 14, 2013, 07:47
anonymous
Here's the UEqn.H in of 2.1.1
surfaceScalarField muEff
"muEff",
twoPhaseProperties.muf()
+ fvc::interpolate(rho*turbulence->nut())
fvVectorMatrix UEqn
fvm::ddt(rho, U)
- fvm::laplacian(muEff, U)
- (fvc::grad(U) & fvc::grad(muEff))
//- fvc::div(muEff*(fvc::interpolate(dev(fvc::grad(U)) ) & mesh.Sf()))
UEqn.relax();
if (pimple.momentumPredictor())
solve
UEqn
fvc::reconstruct
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
- ghf*fvc::snGrad(rho)
- fvc::snGrad(p_rgh)
) * mesh.magSf()
The H operator is constructed by :
fvVectorMatrix UEqn
fvm::ddt(rho, U)
Right?
Old   January 15, 2013, 07:26
fumiya's Avatar
Fumiya Nozaki
I think so.
Fumiya
shchao likes this.
Old   January 28, 2013, 21:27
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, the H operator gives which is defined in Hrv thesis for the implicit terms used in the fvVectorMatrix declaration.
Regards.
Tobi likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   November 13, 2017, 11:05
behzad Ghasemi
behzad-cfd is on a distinguished road
"muEff",
fvVectorMatrix UEqn
fvm::ddt(rho, U)
UEqn.relax();
solve
UEqn
fvc::reconstruct
) * mesh.magSf()
fvVectorMatrix UEqn
fvm::ddt(rho, U)
Right?
I've a question about momentum equation of interFoam. why Area (mesh.magSf()) is multiplied to RHS of equation?
behzad-cfd is offline   Reply With Quote
Old   December 18, 2017, 17:34
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
This is based on the divergence operator. We interpolate the deviatoric part of grad(U) to the face and have to multiply it with the surface normal vector (area of the face). As it is given in Hrv thesis, the divergence is approximately the sum of fluxes through the faces.
behzad-cfd likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   December 18, 2017, 17:40
behzad Ghasemi
Thanks for your great answer Tobias. I''ll read the harvoj jasak's thesis for further information.
Regards,
solving the momentum equation in UEqn. callahance OpenFOAM 2 October 18, 2012 09:38
momentum equation question mauz Main CFD Forum 0 March 26, 2010 11:34
Momentum equation used by mixture model George FLUENT 0 May 19, 2005 13:07
Problem with momentum equation Francisco Main CFD Forum 4 August 5, 2004 20:04
Nonstaggered Grids and Momentum Interpolations S. Wang Main CFD Forum 3 March 2, 2001 13:44
