blockMesh wmake error for OpenFOAM5 on ubuntu on windows
Old   February 8, 2018, 05:11
Default blockMesh wmake error for OpenFOAM5 on ubuntu on windows
R Clement
rclement is on a distinguished road
I am new to OpenFOAM
I have installed OpenFOAM5 on Ubuntu on Windows10 following the instructions on the OpenFOAM web site.
I created a users directory (/home/rclement/OpenFOAM/rclement-5.0/run/) under the OpenFOAM subdirectory and copied the pitzDaily example from the tutorials directory to that location. I then succefully ran this copied tutorial (blockMesh, simpleFoam, and paraFoam).
I then copied the pitzDaily example to a new subdirectory (.../run/Sonic0/). I edited the BlockMeshDict file and tried to run blockMesh. This failed because of a wmake error, the complete output is below.
My question is, why did the blockMesh command work for the pitzDaily but fail for my modified blockmeshdict when the fail appear not be be related to the blockmesh file.
#---------------- output --------------
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 5.x-197d9d3bf20a
Exec : blockMesh
Date : Feb 08 2018
Time : 18:52:50
Host : "DESKTOP-HICV6BE"
PID : 647
I/O : uncollated
Case : /home/rclement/OpenFOAM/rclement-5.0/run/Sonic0
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
"/home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/system/blockMeshDict"
Using #codeStream at line 19 in file "/home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/system/blockMeshDict"
Using #codeStream with "/home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_bd020b3857767f2bdf03dd861d918464b24f 6e5a.so"
Invoking "wmake -s libso /home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/dynamicCode/_bd020b3857767f2bdf03dd861d918464b24f6e5a"
wmake libso /home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/dynamicCode/_bd020b3857767f2bdf03dd861d918464b24f6e5a
/opt/openfoam5/wmake/wmake: line 409: make: command not found
/opt/openfoam5/wmake/wmake: line 412: make: command not found
wmake error: file 'Make/linux64GccDPInt320pt/sourceFiles' could not be created in /home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/dynamicCode/_bd????????
--> FOAM FATAL IO ERROR
Failed wmake "dynamicCode/_bd???????????/platforms/linux64GccDPIInt320pt/lib/libcodeStream_bd????????.so
file: /home/rclement/OpenFOAM/rclement-5.0/run/Sonic0/system/blockMeshDict from line 17 to line 17.
from function static void * Foam:: functionEntries::codeStream::getFunction(const Foam::dictionary&,const Foam:: dictionary&)(Foam::0stream&, const Foam::dictionray&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 218.
FOAM exiting
rclement is offline   Reply With Quote
Old   March 5, 2018, 13:50
AliG
axjjienn is on a distinguished road
I just had this same issue (also new user), for custom non-uniform boundary conditions.
You need to install make in your WSL. Open the Ubuntu terminal, and do a
sudo apt-get install make
That solved the issue for me.
Exec : blockMesh
Date : Feb 08 2018
Time : 18:52:50
PID : 647
I/O : uncollated
nProcs : 1
Create time
FOAM exiting
axjjienn is offline   Reply With Quote
Old   March 5, 2018, 16:57
R Clement
Thanks fr the suggestion axjjienn,
I ended up reinstalling and didn't have the problem come back, so don't know what was causing the original issue.
openfoam 5.0, windows 10, wmake error
[OpenFOAM.org] blockMesh 'command not found' on Ubuntu 16.04 fredb OpenFOAM Installation 5 December 22, 2016 10:13
[solidMechanics] Building solidMechanics in OpenFOAM 1.6-ext on Mac OS X codder OpenFOAM CC Toolkits for Fluid-Structure Interaction 4 January 11, 2014 17:34
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
