November 18, 2018, 06:02 |
Information exchange between processors
Anonymous
Rep Power: 8 |
Hi!
I'm programming a parallel application for interpolation and I need to exchange information between processors. In particular, I have a List p with different size and elements in each processor and I want to merge all p and share it among processors. I split the problem in two parts:
label n=Pstream::nProcs(); DynamicList<point> samplePosCellCenter; // Sharing list samplePosCellCenter among processors // Perhaps there is a more compact way of doing it through // reduce(List<T>, binaryOP<>) //---------------------------------------------------------------------------// // Compiling list on master processor //---------------------------------------------------------------------------// if (Pstream::myProcNo() == 0) { // Output variable for processor 0 forAll(samplePosCellID, cellID) { point cellCenter = mesh.C()[cellID]; samplePosCellCenter.append(cellCenter); } // Information exchange between processors for(label i=1; i<n; i++) { // Local declaration of masterPlaceHolder List<point> masterPlaceHolder; // Create an input stream for processor i IPstream masterStream(Pstream::blocking, i); masterStream >> masterPlaceHolder; // Add elements of placeHolder to samplePosCellCenter forAll(masterPlaceHolder, proci) { point cellCenterI = masterPlaceHolder[proci]; samplePosCellCenter.append(cellCenterI); } } } else { // Create stream to send slavePlaceHolder to the main proc DynamicList<point> slavePlaceHolder; forAll(samplePosCellID, cellID) { point cellCenter = mesh.C()[cellID]; slavePlaceHolder.append(cellCenter); } OPstream slaveStream(Pstream::blocking, 0); slaveStream << slavePlaceHolder; } //---------------------------------------------------------------------------// Code:
//---------------------------------------------------------------------------// // Sharing master's list among slaves //---------------------------------------------------------------------------// if (Pstream::myProcNo() == 0) { // Information exchange between processors for(label i=1; i<n; i++) { // Create an output stream for processor i OPstream masterStream(Pstream::blocking, i); masterStream << samplePosCellCenter; } } else { // Create input stream to send share samplePosCellCenter from master to // slave processors IPstream slaveStream(Pstream::blocking, 0); slaveStream >> samplePosCellCenter; } //---------------------------------------------------------------------------// My question: Is there a cleaner way to merge lists from different processors? Thank you in advance! |
November 21, 2018, 19:15 |
Mark Olesen
Rep Power: 40 |
Not really sure what you want your final access to be. One flat list that is identical on all processors? Is this list appended with/without duplicates? Or do you just want everyone to know everything about each other?
https://www.openfoam.com/documentati...d51a9a321792d9 Eg, Code:
.. taken from laserDTRM.C as an example List<pointField> positions(Pstream::nProcs()); ... fill in per processor Pstream::gatherList(positions); Pstream::scatterList(positions); |
November 24, 2018, 04:48 |
Anonymous
Rep Power: 8 |
Dear Olesen,
Thank you very much for your answer and time. I have one list different in size and contents in each processor and I want everyone to know about each other (to share the contents of the list). For example, for a parallel simulation using 2 cores I could have the following lists: Code:
[0] Processor 0: 1(0 1) [1] Processor 1: 2(1) Code:
[0] Processor 0: 3(0 1 1) [1] Processor 1: 3(0 1 1) Code:
// OpenFOAM #include "fvCFD.H" int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" //---------------------------------------------------------------------------// // Creating a different (both in size and contents) list for each processor //---------------------------------------------------------------------------// // Number of processors label n = Pstream::nProcs(); // Create a different test list in each processor DynamicList<label> prociList; label proci = Pstream::myProcNo(); for (label i=proci; i<n;i++) { prociList.append(i); } // Printing list's elements for each processor Pout<< "Processor " << proci << ": " << prociList << nl; Info<< nl << endl; //---------------------------------------------------------------------------// //---------------------------------------------------------------------------// // Implementing Olesen's reply on cfd-online //---------------------------------------------------------------------------// // Creating a placeholder list List<List<label> > shareList(n); // Transfering prociList into the proci'th element of placeholder // list shareList. This removes the contents of prociList. shareList[proci].transfer(prociList); // Currently, only the proci'th element of list shareList is populated. // Gather the different shareList's of slave processors in master processor Pstream::gatherList(shareList); // Share masters' shareList to the rest of processors Pstream::scatterList(shareList); // Creating a single list with all elements forAll(shareList, listI) { prociList.append(shareList[listI]); } Pout<< "Size of resulting prociList: " << prociList.size() << nl << "prociList in proc " << proci << ": " << prociList << nl; //---------------------------------------------------------------------------// } |
December 6, 2018, 04:34 |
Mark Olesen
Rep Power: 40 |
For what it's worth, you can add some more modern coding - should work with 1712 and later, but you should check.
List<labelList> shareList(Pstream::nProcs()) ; shareList[Pstream::myProcNo()].transfer(prociList); Pstream::gatherList(shareList); Pstream::scatterList(shareList); // Flatten for (labelList& list : shareList) { procList.append(std::move(list)): } |
parallel |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
script for export particle information | archetype | CFX | 2 | August 8, 2017 09:57 |
Socket 2011-3 processors - an overwiew | flotus1 | Hardware | 10 | June 17, 2017 09:47 |
OpenFOAM 2D simulation - Freelancer Job- Information will be provided | sanjar | CFD Freelancers | 0 | March 7, 2017 09:45 |
information from saved data files:Unsteady flow | Atul | FLUENT | 5 | July 27, 2008 20:05 |
