Beginner: How to bridge the gap between basic C++ knowledge to openFOAM programming |
August 9, 2011, 14:32 |
Alex
Rep Power: 15 |
I have a mechanical engineering background with only undergraduate classes in various programming (C++, lingo, VB, html). My goal is to become free to use openFOAM as I please.
I did all the tutorials on http://www.cplusplus.com/doc/tutorial/ to refresh my knowledge and I am still very confused when I'm trying to understand the source code in openFOAM. I get lost trying to get to the source of several layers of classes of code for simple features. What can I do to bridge this gap. Thanks |
August 10, 2011, 10:03 |
Paulo Vatavuk
Rep Power: 17 |
Hi Alex,
I'm also trying to understand some details of the source code and I'm also finding it difficult. There is no detailed manual of the code implementation but you can obtain information distributed in a lot of sources. Here is a list of links that I found useful for understanding the code: 1)Dr. Hvoje Jasak presentation at the 6th OpenFOAM workshop http://www.openfoamworkshop.org/6th_...ak2_slides.pdf 2)Dr. Tommaso Lucchini programming tutorial http://cfd.iut.ac.ir/files/Tutorial,...20Diego%20.pdf 3) The Programmer Guide Addendum that appears in the OpenFOAM wiki has many interesting topics written by different authors: http://openfoamwiki.net/index.php/Ma...rGuideAddendum This list is small but other people may help adding their preferred links. Paulo |
August 10, 2011, 13:07 |
Alex
Rep Power: 15 |
Thanks for this reply. Very helpful.
August 11, 2011, 07:45 |
August 11, 2011, 08:31 |
#5 | |
Alex
Rep Power: 15 |
August 11, 2011, 09:50 |
David Gaden
Rep Power: 22 |
The programmer's guide addendum has been expanded to the "OpenFOAM guide", a subsection of the wiki:
http://openfoamwiki.net/index.php/Ca...OpenFOAM_guide I'm also planning to formalizing this into a pdf-ish programmer's guide for all OpenFOAM users. |
August 11, 2011, 09:51 |
#7 | |
Alex
Rep Power: 15 |
I have had many debugging errors along the way just to get the compiler to work. Two corrections I made to the rampedFixedValueFvPatchField.C file were: Change #1: Code:
template<class Type> rampedFixedValueFvPatchField<Type>::rampedFixedValueFvPatchField ( const fvPatch& p, //const Field<Type>& iF, const DimensionedField<Type, volMesh>& iF, const dictionary& dict ) : fixedValueFvPatchField<Type>(p, iF), refValueLow_("refValueLow", dict, p.size()), refValueHigh_("refValueHigh", dict, p.size()), startRamp_(readScalar(dict.lookup("startRamp"))), endRamp_(readScalar(dict.lookup("endRamp"))), curTimeIndex_(-1) { Info << "Hello from ramp! startRamp: " << startRamp_ << " endRamp: " << endRamp_ << endl; if (dict.found("value")) { fixedValueFvPatchField<Type>::operator== ( Field<Type>("value", dict, p.size()) ); } else { fixedValueFvPatchField<Type>::operator== ( refValueLow_ + (refValueHigh_ - refValueLow_)*currentScale() ); } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //#ifdef NoRepository //# include "rampedFixedValueFvPatchField.C" //#endif // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************************************* // Code:
... Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U icoFoamRamped: symbol lookup error: /home/alexander/OpenFOAM/alexander-2.0.1/platforms/linux64GccDPOpt/lib/libMyBCs.so: undefined symbol: _ZN4Foam28rampedFixedValueFvPatchFieldINS_6VectorIdEEEC1ERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE alexander@alexander-G50VT:~/OpenFOAM/alexander-2.0.1/run/cavity$ |
August 11, 2011, 09:53 |
Paulo Vatavuk
Rep Power: 17 |
The NUMAP 2009 also has interesting lectures: http://powerlab.fsb.hr/ped/kturbo/Op...2009/lectures/ |
August 11, 2011, 10:07 |
#9 |
Paulo Vatavuk
Rep Power: 17 |
Hi Alex,
I haven't tried these tutorials yet. In the slides, Dr. Lucchini mentions version 1.41 of OpenFOAM. I don’t know if this tutorial is compatible with version 2.01. |
August 11, 2011, 14:51 |
#10 |
Alex
Rep Power: 15 |
Thanks anyway vatavuk. I will continue to debug. In the meantime there is such a wealth of information on this thread that I will continue to learn and come back to the tommaso problem.
Thanks again. |
August 13, 2011, 08:27 |
#11 |
Paulo Vatavuk
Rep Power: 17 |
Hi Marupio,
I've been navigating the wiki for some time but haven't seen this guide until I saw your link above. Sometimes it's difficult to find some pages in the wiki. Congratulations for your guide it will help many people. Making a pdf of it will be even better. |
February 15, 2012, 16:11 |
#12 |
Teng Wu
Rep Power: 14 |
Hi Alex,
Have you successfully completed the ramped boundary condition in Dr. Tommaso's programming tutorial now? These days I'm also trying to figure out the debugging errors during the compiling process. Some issues similar with yours shows up... Teng |
July 9, 2015, 12:34 |
#13 |
Paulo Vatavuk
Rep Power: 17 |
I noticed that the links in my post #2 are broken, so I made a search and found the updated links: 1)Dr. Hvoje Jasak presentation at the 6th OpenFOAM workshop http://iweb.dl.sourceforge.net/proje...ak2_slides.pdf 2)Dr. Tommaso Lucchini programming tutorial http://www.tfd.chalmers.se/~hani/kur...ngTutorial.pdf 3) The Programmer Guide Addendum (now openFOAM guide): http://openfoamwiki.net/index.php/OpenFOAM_guide Best Regards, Paulo |
February 13, 2017, 22:21 |
#14 |
Declan
Rep Power: 9 |
This is still a very relevant thread for those looking to dive into the source code for the first time.
This course by Joel Guerrero has some excellent material, see module 7 for programming. http://www.wolfdynamics.com/our-serv...ing.html?id=50 If anyone else has useful links please share! |
July 10, 2018, 05:34 |
#15 |
Sebastian
Rep Power: 12 |
Since I find it very helpfull, I want to share the tutorial of the user Artur here as well. It perfectly fits into the topic of this thread.
OpenFOAM programming tutorials for beginners |
A book for a beginner wanting to learn programming | frank | Main CFD Forum | 9 | May 12, 2014 23:15 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFoam programming | prapanj | OpenFOAM | 10 | March 18, 2010 07:23 |
Programming in OpenFOAM | vinu | OpenFOAM | 2 | July 11, 2009 10:16 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
