October 1, 2018, 10:05 |
Gradient Calculation on cell vertices
Rep Power: 11 |
Hello OpenFoam-community,
I have found many publications using the least-square-method to calculate the gradient of a scalarField at cell vertices (and not at cell centers). Now I need to do this as well for my code, but can not find the Header-File or the function to do this. The User-Manual and the Programmer-Manual mention gradient at cell centers only. Is there an already written Header-file in OpenFoam to calculate gradient at cell vertices? Thanks a lot, K.C. |
October 2, 2018, 07:22 |
Tobias Holzmann
Rep Power: 51 |
Dear K.C.,
do you mean cell vertices or face centers? Out of the box I just have the following in mind: - calculate the gradient at face centers - interpolate the gradients at face centers to cell vertices
Keep foaming, Tobias Holzmann |
October 2, 2018, 08:29 |
Rep Power: 11 |
Hello Tobi,
thanks for your reply. I mean the cell vertices (e.g. 8 for a cube). A cell consists of faces. A face consists of edges and the edge connects two vertices/points. So I want to calculate a pointVectorField and not a surfaceVectorField. Furthermore I dont know how you would calculate the vector gradient on faces (except by interpolation). The surface normal Gradient can't be interpolated into a vector on vertices in my opinion. Can you explain a bit more detailed? Greets, K.C. |
October 2, 2018, 09:06 |
#4 | |
Tobias Holzmann
Rep Power: 51 |
[quote] ... calculate the vector gradient on faces (except by interpolation). [/code] Out of the box, I donīt think that this is possible. However, you could check the least square schemes available in OpenFOAM to get a better feeling how they do it here (also available for point and edge limiting stuff or something like that). Maybe this is what you are searching for.
October 4, 2018, 11:28 |
#5 | ||
Rep Power: 11 |
it was your idea of calculating gradient on faces. I hoped you had an idea of calculating gradient in vector form on faces. But maybe I missunderstood you. Quote:
October 4, 2018, 14:01 |
#6 | ||
Tobias Holzmann
Rep Power: 51 |
Just see: Code:
Unknown grad scheme linear Valid grad schemes are : 11 ( Gauss cellLimited cellLimited<Venkatakrishnan> cellLimited<cubic> cellMDLimited edgeCellsLeastSquares faceLimited faceMDLimited fourth leastSquares pointCellsLeastSquares ) Quote:
The gradient calculation I meant was gradient calculation at cell center, interpolate to face center and interpolate to edges. However, this is not what you were searching for.
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
[General] Wrong Calculation of Cell Volume | olli191 | ParaView | 1 | August 3, 2016 04:09 |
Difference between cell gradient and cell derivative macros | mohammadx90 | Fluent UDF and Scheme Programming | 2 | February 7, 2015 19:40 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
Prediction of gradient at the cell center for cell-centered finite volume method | openfoammaofnepo | Main CFD Forum | 4 | March 23, 2014 15:07 |
