How to build a variable solution domain
Old   September 5, 2018, 13:43
Default How to build a variable solution domain
Wenming Yang
ywem is on a distinguished road
Dear all,
I need to solve a problem whose physical domain is changing with time. My thought is that the domain is build and mesh at each run time and using parameterizing modelling in the blockMeshDict. Following this idea, I want to include the blockMesh.C in the main routine, but failed after several times of try. Does anyone has better ideas?
Thanks a lot.
ywem is offline   Reply With Quote
Old   September 6, 2018, 08:52
Thomas Oliveira
t.oliveira is on a distinguished road
Dear Yang,
See if this presentation by Hrvoje Jasak and Henrik Rusche can help you and give you keywords for further research.
Kind regards,
Thomas
t.oliveira is offline   Reply With Quote
Old   September 6, 2018, 08:55
Michael Alletto
mAlletto will become famous soon enough
the dynamic mesh of openfoam or the overset Mesh available in openfoam.com and openfaom extend may help you
mAlletto is offline   Reply With Quote
Old   September 6, 2018, 09:59
Wenming Yang
Dear Oliveira and Alletto,
Thank you for your advices. I will have a try.
Best,
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? asitav SU2 2 November 21, 2018 19:11
Can CFX model periodic heat transfer problem Ethan_Sparkle CFX 41 June 14, 2017 07:22
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Different diffusivity for additional variable in Fluid and porous domain ftab CFX 4 June 27, 2012 13:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
