Adding non-orthogonal corrector to snGrad in fixedValueBcs
Like Tree1Likes
  • 1 Post By ssss
Old   April 18, 2015, 08:13
Default Adding non-orthogonal corrector to snGrad in fixedValueBcs
anonymous
ssss is on a distinguished road
I'm willing to add non-orthogonal correction in the boundaries when I call the fvc::snGrad() function of a volScalarField.
The reason why I'm would to add this special non-orthogonal correction is described in the posts:
http://www.cfd-online.com/Forums/ope...tml#post382173
http://www.cfd-online.com/Forums/ope...d-surface.html
Basically OpenFOAM doesn't use non-orthogonal correction in the boundaries and thus high-oscillating results for the the heat flux in the boundaries are obtained.
In order to implement a new BC, I copied the original fixedValueBC, and I named it myFixedValue, and the I added the following function to the .C
template<class Type>
tmp<Field<Type> > myFixedValueFvPatchField<Type>::snGrad() const
return (*this - this->patchInternalField())*this->patch().deltaCoeffs();
This is the original definition of snGrad in fvPatch.C. I also added to the .H file:
virtual tmp<Field<Type> > snGrad() const;
And the it compiles OK. The problem appears when I modify the snGrad function in order to use non-orthogonal correctors:
    const fvPatchField<vector>& gradField =this->patch().lookupPatchField<volVectorField, vector>("grad(T)");
    vectorField n = this->patch().nf();
    vectorField delta = this->patch().delta();
    //- correction vector
    vectorField k = delta - n*(n&delta);
    return
        *this
      - (this->patchInternalField() + (k&gradField.patchInternalField()))
(The code is obtained from http://www.cfd-online.com/Forums/ope...tml#post382173). When I compile this new code I obtain a lot of errors, here you will find the first lines of the log:
In file included from myFixedValueFvPatchField.H:219:0,
                 from myFixedValueFvPatchFields.H:29,
                 from myFixedValueFvPatchFields.C:26:
myFixedValueFvPatchField.C: In member function ‘virtual Foam::tmp<Foam::Field<Type> > Foam::myFixedValueFvPatchField<Type>::snGrad() const’:
myFixedValueFvPatchField.C:149:87: error: expected primary-expression before ‘,’ token
     const fvPatchField<Type>& gradField =this->patch().lookupPatchField<volVectorField, Type>("grad(T)");
myFixedValueFvPatchField.C:149:93: error: expected initializer before ‘>’ token
In file included from /opt/openfoam231/src/OpenFOAM/lnInclude/doubleFloat.H:30:0,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/floatScalar.H:38,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/scalar.H:39,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/IOstream.H:49,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/Ostream.H:39,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/OSstream.H:39,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/messageStream.H:220,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/error.H:51,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/UListI.H:26,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/UList.H:393,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/wordList.H:42,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/patchIdentifier.H:38,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/polyPatch.H:42,
                 from /opt/openfoam231/src/finiteVolume/lnInclude/fvPatch.H:39,
                 from /opt/openfoam231/src/finiteVolume/lnInclude/fvPatchField.H:47,
                 from myFixedValueFvPatchField.H:58,
/opt/openfoam231/src/OpenFOAM/lnInclude/products.H: In instantiation of ‘class Foam::innerProduct<Foam::Vector<double>, double>’:
/opt/openfoam231/src/OpenFOAM/lnInclude/FieldFunctions.C:774:1:   required by substitution of ‘template<class Type1, class Type2> Foam::tmp<Foam::Field<typename Foam::innerProduct<Type1, Type2>::type> > Foam::operator&(const Foam::UList<T>&, const Foam::tmp<Foam::Field<Type2> >&) [with Type1 = Foam::Vector<double>; Type2 = double]’
myFixedValueFvPatchField.C:161:41:   required from ‘Foam::tmp<Foam::Field<Type> > Foam::myFixedValueFvPatchField<Type>::snGrad() const [with Type = double]’
myFixedValueFvPatchFields.C:41:1:   required from here
/opt/openfoam231/src/OpenFOAM/lnInclude/products.H:97:13: error: no type named ‘type’ in ‘class Foam::typeOfRank<double, -1>’
     >::type type;
myFixedValueFvPatchField.C: In instantiation of ‘Foam::tmp<Foam::Field<Type> > Foam::myFixedValueFvPatchField<Type>::snGrad() const [with Type = double]’:
myFixedValueFvPatchField.C:161:41: error: no match for ‘operator&’ (operand types are ‘Foam::vectorField {aka Foam::Field<Foam::Vector<double> >}’ and ‘Foam::tmp<Foam::Field<double> >’)
myFixedValueFvPatchField.C:161:41: note: candidates are:
In file included from /opt/openfoam231/src/OpenFOAM/lnInclude/word.H:144:0,
                 from /opt/openfoam231/src/OpenFOAM/lnInclude/wordList.H:41,
Attached to the post you will find the full log and the files of the new boundary condition.
So does anyone know if there is a solution to this? I think that there might be problems with te templateFunction, as I'm only using vectors for every template, but I don't know how to change this.
Thank you very much
Zhiheng Wang likes this.
ssss is offline   Reply With Quote
Old   October 9, 2018, 12:40
Reviewer #2
randolph is on a distinguished road
why not just put orthogonal layer near the boundary and avoid all these hassles?
This paper may help
https://www.sciencedirect.com/scienc...78475417303762
randolph is online now   Reply With Quote
Old   October 10, 2018, 00:53
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I never realized that problem in the field of computational fluid dynamics and heat-flux difficulties (maybe, because I never made complex calculations) but within my solid mechanic solver as mentioned by Phil Cardiff (by the way, he made a nice - long - article about solid mechanics and FVM); very stiff problems and the boundaries are highly explicit. However, as I already did this, I will refer you to the foam-extend solidMechanics solvers to check how to implement the non-ortho correction. It is not difficult to obtain, so there should not be any problem. If you gain any stability increase, please let us know.
By the way, the code you posted is related to foam-extend and is already a while ago. Objects/classes/functions changes during time. Thus, you have to find the correct functions and objects. I suggest using Doxygen for that purpose.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 08:43
chtMultiRegionSimpleFoam: strange error samiam1000 OpenFOAM Running, Solving & CFD 26 December 29, 2015 22:14
Problems in my first attempt with chtMultiRegionSimpleFoam zfaraday OpenFOAM Running, Solving & CFD 1 April 8, 2014 18:20
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 17:16
