postProcessing "grad(U")
Like Tree1Likes
  • 1 Post By uckmhnds
Old   September 5, 2017, 10:12
Default postProcessing "grad(U")
Livia Adinolfi
liviaadi is on a distinguished road
Dear Foamers,
I would like to calculate the shear stresses in a laminar simulation of an open channel flow. I am using the interFoam solver with OF 4.1
I was trying to postProcess and calculate grad(U). But I have this error:
Executing functionObjects
--> FOAM Warning :
From function bool Foam::functionObjects::regionFunctionObject::store (Foam::word&, const Foam::tmp<T>&, bool) [with ObjectType = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/regionFunctionObjectTemplates.C at line 61
Cannot store cache-able field with the named used in the cache.
Either choose a different name or cache the field and use the 'writeObjects' functionObject.
--> FOAM Warning : functionObject grad: Cannot find required field U
I know that there are many threads on this topic and I have read something, but still I did not solve this problem.
Can anyone help me ?
Thanks in advance.
liviaadi is offline   Reply With Quote
Old   September 5, 2017, 11:30
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Which command exactly did you type?
Did you include something like "-field U" or "-fields (U)" in the argument list, such that the utility knows that it should read U from file?
floquation is offline   Reply With Quote
Old   September 5, 2017, 12:35
Livia Adinolfi
after the simulation:
interFoam -postProcess -func "grad(U)".
I tried also to do it in runtime by typing in the ControlDict file:
functions
grad
type grad(U);
libs ("libFVFunctionObjects.so");
fieldName "U";
resultName "gU";
but I have always the same error.
What would you suggest ?
Thanks a lot!
Old   April 6, 2020, 07:06
Gazi Yavuz
uckmhnds is on a distinguished road
this is too late answer. though it would be helpful for others. the function should be like;
functions
gradient /could be anything you name
type grad;
libs ("libfieldFunctionObjects.so");
field U;
writeControl writeTime;
osu_tom likes this.
uckmhnds is offline   Reply With Quote
Old   October 11, 2021, 04:20
Default answer
Masoumeh
ms.hashempour is on a distinguished road
just type:
ms.hashempour is offline   Reply With Quote
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 07:04
PostProcessing of particle source boesendorfer FLOW-3D 3 October 26, 2017 16:22
Postprocessing in 3d - Creating part of a surface shankara.2 FLUENT 0 July 13, 2009 17:33
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
