simpleDyMFoam on v1806
Old   November 8, 2018, 08:15
Post simpleDyMFoam on v1806
gamemakerh is on a distinguished road
Hey guys,
I'm having problems with adaptive mesh refinement integration into the OpenFOAM v1806.
The aim of the project is relatively simple - execute Steady-State, 2D thermal (buoyantBousinessqSimpleFoam) simulation with Adaptive Mesh Refinement (AMR).
I managed to compile 2D mesh refinement addon which was created by Luca Cornolti. Big Clap for him !!!
Unfortunately, his solver was working only with transient simulations (interFoam etc.)
I found simpleDyMFoam solver created by some Japanese guy named "Penguin" (unfortunately the explanation on how to develop and compile this solver is no longer available on his website). I was unable to compile this solver for OpenFOAM-v1806.
I've tried to include more header files according to the original simpleFoam solver, but the compilation was unsuccessful.
Maybe someone has working Steady-State solver which are able to work using 2D adaptive mesh refinement?
Please check attached files below.
UPDATE
After some adjustments I managed to to launch simpleDyMFoam using 2D Adaptive Mesh Refinement. But I encountered the problem regarding the unrefinement. maybe someone interested into deeper look at this problem ? I could upload working simpleDyMFoam solver for v1806.
I'm getting this error log
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicRefineFvMesh2D
Detected 438 cells that are protected from refinement. Writing these to cellSet protectedCells.
SIMPLE: convergence criteria
    field U      tolerance 0.001
    field "p.*"  tolerance 0.001
    field T      tolerance 0.001
    field k      tolerance 0.001
    field omega  tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
No finite volume options present
Starting time loop
Reading surface description:
    yNormal
streamLine streamLines:
    Employing velocity field U
    automatic track length specified through number of sub cycles : 1
runTimePostProcessing postPro1: reading post-processing data
Time = 1
Selected 13294 cells for refinement out of 13440.
Refined from 13440 to 53322 cells.
Selected 0 split edges out of a possible 13294.
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.005390501, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.006547034, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.9997273, Final residual = 0.006281913, No Iterations 16
GAMG:  Solving for p, Initial residual = 0.01727778, Final residual = 0.0001585316, No Iterations 2
time step continuity errors : sum local = 2.528902e-05, global = 1.842507e-08, cumulative = 1.842507e-08
ExecutionTime = 7.11 s  ClockTime = 8 s
Time = 2
Selected 51713 cells for refinement out of 53322.
Refined from 53322 to 208461 cells.
Selected 0 split edges out of a possible 51954.
Setting residual field for first solver iteration for solver field: Ux
smoothSolver:  Solving for Ux, Initial residual = 0.2805062, Final residual = 0.001492275, No Iterations 2
Setting residual field for first solver iteration for solver field: Uy
smoothSolver:  Solving for Uy, Initial residual = 0.2748859, Final residual = 0.001400735, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.6047205, Final residual = 0.005748263, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.004981731, Final residual = 4.600868e-05, No Iterations 9
time step continuity errors : sum local = 6.968632e-05, global = 5.084545e-09, cumulative = 2.350962e-08
ExecutionTime = 17.19 s  ClockTime = 22 s
Time = 3
smoothSolver:  Solving for Ux, Initial residual = 0.2000615, Final residual = 0.0007128696, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.2088684, Final residual = 0.0005146371, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.04054855, Final residual = 0.0002980836, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.006104533, Final residual = 4.91343e-05, No Iterations 4
time step continuity errors : sum local = 0.0001698377, global = -6.749423e-10, cumulative = 2.283467e-08
ExecutionTime = 21.99 s  ClockTime = 27 s
Time = 4
Selected 3 split edges out of a possible 51954.
--> FOAM FATAL ERROR:
Problem : edge has too few face neighbours:1(271578)
edge:13241 vertices:(27584 27592) coords:(-39.15004 -14.59622 0)(-39.36746 -14.70492 0.5)
    From function void Foam::removeFaces::setRefinement(const labelList&, const labelList&, const labelList&, Foam::polyTopoChange&) const
    in file polyTopoChange/polyTopoChange/removeFaces.C at line 867.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::removeFaces::setRefinement(Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::polyTopoChange&) const at ??:?
#3  Foam::hexRef2D::setUnrefinement(Foam::List<int> const&, Foam::polyTopoChange&) at ??:?
#4  Foam::dynamicRefineFvMesh2D::unrefine(Foam::List<int> const&) at ??:?
#5  Foam::dynamicRefineFvMesh2D::update() at ??:?
#6  ? at ??:?
#7  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#8  ? at ??:?
Aborted (core dumped)
gamemakerh is offline   Reply With Quote
adaptive mesh refinement, amr, dynamic mesh adaption, solver, steady state
[OpenFOAM.com] Problem installing v1806 jormollo OpenFOAM Installation 2 October 10, 2018 09:48
[OpenFOAM.com] compile v1806 on Ubuntu 1804? phsieh2005 OpenFOAM Installation 6 August 23, 2018 12:38
v1806 soloshingTank3D6DoF error when running in parallel phsieh2005 OpenFOAM 0 July 15, 2018 12:31
[Commercial meshers] v1806 ccm utility shixiangyu OpenFOAM Meshing & Mesh Conversion 2 July 11, 2018 20:49
[OpenFOAM.com] v1806: Problems compiling on Ubuntu via WSL dela OpenFOAM Installation 1 July 10, 2018 02:45
