Parallel Programming question about IPstream and OPstream |
December 23, 2018, 21:02 |
Yan Zhang
Rep Power: 12 |
Hi everyone,
I met a question about message sending and receiving. What I want to do is: each slave sends a fvPatchScalarField to master, and do some manipulation in master, then send other fvPatchScalarField back to each slave. Here is my first attempt: Code:
forAll(input_.boundaryField(), patchi) { const fvPatchScalarField& inputFaces = input_.boundaryField()[patchi]; fvPatchScalarField& resultFaces = result_.boundaryFieldRef()[patchi]; if (Pstream::master()) { List<autoPtr<IPstream>> IPL(nProc - 1); List<autoPtr<OPstream>> OPL(nProc - 1); for(label iProc = 1; iProc < nProc; iProc++) { IPL[iProc - 1].set(new IPstream(Pstream::commsTypes::blocking, iProc)); OPL[iProc - 1].set(new OPstream(Pstream::commsTypes::blocking, iProc)); } //update master forAll(inputFaces, facei) { getResult ( inputFaces[facei], resultFaces[facei] ); } // update each slave for(label iProc = 1; iProc < nProc; iProc++) { scalarField inputFacesTemp; IPL[iProc - 1]()() >> inputFacesTemp; scalarField resultFacesTemp(inputFacesTemp.size()); forAll(inputFacesTemp, facei) { getResult ( inputFacesTemp[facei], resultFacesTemp[facei] ); } OPL[iProc - 1]()() << resultFacesTemp; } } else { OPstream(blocking,Pstream::masterNo())() << dynamic_cast<scalarField&>(inputFaces); IPstream(blocking,Pstream::masterNo())() >> dynamic_cast<scalarField&>(resultFaces); } } Let us suppose patch numbers in master is 4, and patch numbers in slave1 is 5. Then in master, the loop times is 4. It should receive 4 scalarFields and send 4 scalarFields in master. But in slave1, it will send 5 scalarFields and receive 5 scalarFields. Send and receive do not match! Here is my second try (simplified, scalar on behalf of scalarField): Code:
#include "fvCFD.H" int main(int argc, char *argv[]) { #include "setRootCaseLists.H" label nProc = Pstream::nProcs(); if (Pstream::master()) { List<List<autoPtr<IPstream>>> IPL(nProc - 1); List<List<autoPtr<OPstream>>> OPL(nProc - 1); for(label iProc = 1; iProc < nProc; iProc++) { IPL[iProc - 1].resize(5); OPL[iProc - 1].resize(5); for(label i = 1; i < IPL[iProc - 1].size(); i++) { IPL[iProc - 1][i].set(new IPstream(Pstream::commsTypes::blocking, iProc)); OPL[iProc - 1][i].set(new OPstream(Pstream::commsTypes::nonBlocking, iProc)); scalar b; IPL[iProc - 1][i]()() >> b; Info << "b===" << b <<endl; OPL[iProc - 1][i]()() << b; Info << "send b over !!!" <<endl; } } } else { for(label i = 1; i < 5; i++) { Pout << "I am in proc ID: ===" << Pstream::myProcNo() << "i ===" << i <<endl; scalar a = Pstream::myProcNo(); OPstream(Pstream::commsTypes::blocking, Pstream::masterNo())() << a; scalar c; IPstream(Pstream::commsTypes::blocking, Pstream::masterNo())() >> c; Pout << "c===" << c <<endl; } } Info<< "End\n" << endl; return 0; } Could anyone help me?
https://openfoam.top |
Using IPstream and OPstream | Novel | OpenFOAM Programming & Development | 0 | April 7, 2017 03:29 |
