Compile error when modifying LESdelta
Prev Previous Post   Next Post Next
Old   January 26, 2019, 09:40
Unhappy Compile error when modifying LESdelta
王莹
Alisa_W is on a distinguished road
I am modifying delta for my turbulence model. However, when I compiled it, I faced some unexpected errors, which I thought brought by my wrong use of grammar or the declaration of '*.H'. I am not so familiar with OF language.
Maybe they are quite easy problems. I hope anyone can help me or give me some suggestion. Thanks a lot!!!
p.s. I modified two versions: Adelta & A2delta. They have similar error, so I think if one version's corrected, another can also work.
Here is the info of error in Adelta:
OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/PtrList.C: In instantiation of Foam::PtrList<T>::~PtrList() [with T = Foam::fvsPatchField<Foam::Vector<double> >]鈥?
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/FieldField.H:74:7: required from 鈥楩oam::GeometricField<Type, PatchField, GeoMesh>::~GeometricField() [with Type = Foam::Vector<double>; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]鈥?/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/tmpI.H:111:13: required from 鈥楩oam::tmp<T>::~tmp() [with T = Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>]鈥?LES/LESdeltas/ADelta/ADelta.C:72:56: required from here
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/PtrList.C:133:13: warning: possible problem detected in invocation of delete operator: [-Wdelete-incomplete]
delete ptrs_[i];
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/PtrList.C:133:13: warning: invalid use of incomplete type 鈥榗lass Foam::fvsPatchField<Foam::Vector<double> >鈥?In file included from lnInclude/turbulenceModel.H:44:0,
from lnInclude/LESdelta.H:38,
from LES/LESdeltas/ADelta/ADelta.H:41,
from LES/LESdeltas/ADelta/ADelta.C:26:
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/finiteVolume/lnInclude/surfaceFieldsFwd.H:49:7: note: declaration of 鈥榗lass Foam::fvsPatchField<Foam::Vector<double> >鈥? class fvsPatchField;
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/PtrList.C:133:13: note: neither the destructor nor the class-specific operator delete will be called, even if they are declared when the class is defined
delete ptrs_[i];
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/GeometricField.C:940:8: required from 鈥榖ool Foam::GeometricField<Type, PatchField, GeoMesh>::writeData(Foam::Ostream&) const [with Type = Foam::Vector<double>; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]鈥?LES/LESdeltas/ADelta/ADelta.C:143:1: required from here
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:627:23: error: invalid use of incomplete type 鈥榗onst class Foam::fvsPatchField<Foam::Vector<double> >鈥? os << indent << this->operator[](patchi).patch().name() << nl
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/PtrListI.H:159:60: error: invalid use of incomplete type 鈥榗lass Foam::fvsPatchField<Foam::Vector<double> >鈥? << "hanging pointer of type " << typeid(T).name()
/home/alisa/OpenFOAM/OpenFOAM-v3.0+/wmake/rules/General/transform:8: recipe for target '/home/alisa/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Opt/src/TurbulenceModels/turbulenceModels/LES/LESdeltas/ADelta/ADelta.o' failed
make: *** [/home/alisa/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Opt/src/TurbulenceModels/turbulenceModels/LES/LESdeltas/ADelta/ADelta.o] Error 1
Alisa_W is offline   Reply With Quote
compile, delta, error, modify
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 04:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
