How to change the $(FOAM_USER_LIBBIN) to other path?
Like Tree1Likes
  • 1 Post By nsf
Old   April 6, 2019, 02:52
Default How to change the $(FOAM_USER_LIBBIN) to other path?
Jiadong Wang
jiadongw is on a distinguished road
Hello Foamers,
Usually I compiled a modified library in my PC by changing the /Make/files to:
LIB = $(FOAM_USER_LIBBIN)/libNew00
Everything works well. This will build a folder of /platforms on the Home directory.
Now I’m working on an HPC cluster and don’t have the permission to build a directory in /Home folder. Every single user has a personal directory, e.g. /Roy11 on other directory.
So if I want to compile a new library on this personal directory (/Roy11) of HPC cluster, how should I define the ‘LIB =’ in the /Make/files?
Thank you.
jiadongw is offline   Reply With Quote
Old   April 7, 2019, 01:54
nsf
Nicolas Edh
nsf is on a distinguished road
How about
$(LIB=$(FOAM_SITE_LIBBIN)/libNew
You could also replace the $(...) With an absolute path instead and include the lib in your system/controlDict with an absolute path or add your lib directory to LD_LIBRARY_PATH.
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/Roy11/somepath
jiadongw likes this.
nsf is offline   Reply With Quote
Old   April 7, 2019, 21:01
Jiadong Wang
Hello Nicolas,
Thank you very much for reply, it's definitely what I need.
I'll try that soon.
Best wishes.
library path
Thermal phase change model Piti CFX 1 January 14, 2021 10:03
Extruding surface/domain mesh in helical path rahulksoni Pointwise & Gridgen 6 March 4, 2018 10:57
[waves2Foam] Error: "The directory path WAVES_DIR=:/home/waves2Foam does not exist." Dmitrjs OpenFOAM Community Contributions 3 June 27, 2014 08:53
Help with writing a macro/UDF_file/script to change BC at regular time step intervals Codophobia Fluent Multiphase 0 April 24, 2014 10:07
Change path in Tecplot Layout pascool Tecplot 1 November 14, 2012 10:36
