molar mass of mixture
Old   January 9, 2013, 09:14
Default molar mass of mixture
Marshak is on a distinguished road
Can anyone kindly let me know how to calculate the molar mass of a gas mixture in each cell. I am using hsCombustionThermo.
Marshak is offline   Reply With Quote
Old   May 2, 2019, 15:29
charles4allme is on a distinguished road
Were you able to figure it out
charles4allme is offline   Reply With Quote
Old   May 3, 2019, 03:46
raumpolizei is on a distinguished road
Hey Charles,
the mixture averaged molar mass can be accessed via the mixture classes in the thermophysicalModels library (at least in my version, of1612). The mixture itself is a "part" of the thermo object which is used in your solver. In order to access it, something similar to
const auto mixture = thermo.composition();
should work. In order to output the mixture averaged molar mass, you could do something like this (not tested):
// create new field to get the mixture at write time
volScalarField mixtureMolarMass
    IOobject
        "WMixture",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mixture.W()
Though it is unlikely, the function you have to call may be different for your specific case (here I assumed the mixture type you are using is derived from the basicSpecieMixture class).
Cheers
RP
raumpolizei is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Use of FLUENT Mixture model with mass source ckwollongong FLUENT 0 August 29, 2012 22:04
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 08:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 08:14
