Entrywise matrix multiplication (Hadamard or Schur multiplication) |
April 25, 2014, 06:10 |
Thilo Franke
Rep Power: 12 |
i have a really simple question, but i didn't find the answer in the forum search or the programmer manual. I'd like to multiply two volScalarFields entrywise. This is also called Hadamard or Schur product. Example: A ○ B = C with c11 = a11 * b11 (similar to the matrix addition) How is this done in OpenFoam? Thanks in advance Thilo |
April 26, 2014, 14:50 |
Fumiya Nozaki
Rep Power: 18 |
You might want to try volScalarField C = A * B; //C[celli]=A[celli]*B[celli] where A[celli]: value of A at celli-th cell center Hope this helps, Fumiya
[Personal]
April 28, 2014, 05:16 |
Thilo Franke
Rep Power: 12 |
Hi Fumiya,
thanks for your answer. I thought, * would be the Outer Product in OpenFoam when handeling tensors. So it is defined in another way with matrixVolFields? I have found over the weekend the function cmptMultiply. Is the result the same? Is there a recommendation for which function to use? Greetings Thilo |
July 18, 2019, 07:15 |
Rishikesh
Rep Power: 10 |
Did you find the implementation of Hadamard product? Regards, mrishi |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
OpenFOAM version 1.6 details | lakeat | OpenFOAM Running, Solving & CFD | 42 | August 26, 2009 21:47 |
