dispersion with radial velocity
Old   September 10, 2019, 14:55
Default dispersion with radial velocity
CharlineF is on a distinguished road
Dear OpenFoam users,
I'm trying to simulate the dispersion of a plume with an initial radial velocity of around 10 m/s (the plume is expanding in all the directions).
I'm working in incompressible with pimpleFoam and I've set a concentration scalar (dye), as I would have set temperature.
Would you know how I can set the initial velocity of the plume?
I've tried to use funkySetField but it does not work at all (it works well for a vertical initial velocity but fails when I set a radial velocity - it might be due to the fact that I try to expand something that cannot be expanded in incompressible because a negative pressure appears in the center of the plume and stop the dispersion).
I've also tried to set a concentration source, as well as a velocity source or a pressure source. But it's not working neither, I don't succeed to give the initial "push".
Does someone have an idea about how to solve the problem? It would be a great help to me.
Thank you very much in advance,
Charline
CharlineF is offline   Reply With Quote
Old   September 12, 2019, 14:16
no idea ?
Old   September 13, 2019, 02:59
raumpolizei is on a distinguished road
Just a weird idea: Maybe you could create a spherical mesh (computational domain = space between two spheres) and set the velocity normal to the inner boundary to be 10 m/s. I think the pressure could then adapt. In 2D it would be a circle in a circle.
raumpolizei is offline   Reply With Quote
Old   September 13, 2019, 12:24
Hi Raumpolizei,
Thank you for your reply. I will have a try ! I'm running out of ideas right now so thank you
dispersion, pimplefoam, radial velocity
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 09:45
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
finding radial velocity using continuity equation bala_gk1988 OpenFOAM Programming & Development 0 October 13, 2017 08:37
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 08:35
Axial, Radial, Tangental velocity in FLUENT post Barri FLUENT 2 March 6, 2008 20:29
