Rep Power: 7 ![]() |
Hi everybody
Either this will be obvious to most of you or else it will be baffling to all. I have no idea and so I have to give it a shot. Here is a short excerpt from my createFields.H : ......... Info<< "Reading field Fa, Fs \n" << endl; volScalarField Fa ( IOobject ( "Fa", runTime.timeName(), airMesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), airMesh ); volScalarField Fs ( IOobject ( "Fs", runTime.timeName(), solidMesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), solidMesh ); .......... and what follows is a relevant excerpt from my C code: ............... // patch airsolid is defined in the case dictionaries polyMesh for both meshes //airMesh and solidMesh // the two meshes were created independently of each other. They only share the common interface airsolid in the geometry const label id1= airMesh.boundaryMesh().findPatchID"airsolid"); const fvPatch& patch1 = airMesh.boundary()[id1]; const label id2= solidMesh.boundaryMesh().findPatchID"airsolid"); const fvPatch& patch2 = solidMesh.boundary()[id2]; scalarField dummy(patch1.size(), scalar(0) ); forAll(patch1, i) { dummy[i] = Fa[patch1.faceCells()[i] ] - ????; // the above line is my problem. // by ???? I mean some kind of interpolation of the values on the solid side: // Fs[patch2.faceCells()[j] ] where the values of j will depend on the // current value of i // (of course, j lies in the range 0 to patch2.size) } ............ The question is whether any such mapping actually exist in OF. At any rate, best regards to the community regardless of what come out of this inquiry. |
Can't get chtMultiRegionSimpleFoam to working. | shiromaniac | OpenFOAM Running, Solving & CFD | 11 | October 18, 2021 08:40 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
