November 11, 2019, 15:48 |
Dam Break zero G
Josh McCraney
Rep Power: 8 |
Hi All!
In using the dam break tutorial, if I turn gravity off, how do I pin the contact line? Does anyone know? Thanks! Josh |
November 12, 2019, 06:10 |
Rep Power: 12 |
I might be wrong but if by turning off gravity you mean that you've 'zero-ed' the corresponding direction in 'g' dictionary and by contact line you mean the initial field separation at t_0, then isn't it just a matter of using SetFields initialization and running the solver..?
If it's an error that led you to ask for support then it may be better to post it here. |
November 12, 2019, 10:19 |
#3 | |
Josh McCraney
Rep Power: 8 |
When the contact line is pinned, this implies flow will not creep along or recede on any wall. |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Dam break simulation water level decreases over time | aarratia | FLUENT | 1 | May 9, 2014 10:25 |
compressible dam break simulation | smsanth | OpenFOAM Running, Solving & CFD | 0 | September 2, 2013 02:51 |
3D dam break modeling(earthen dam) | yasharif | FLUENT | 0 | December 11, 2011 01:25 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
