CHTC-based source term
Old   December 2, 2019, 04:21
Default CHTC-based source term
M.E. is on a distinguished road
I'm trying to implement a convective heat transfer coefficient based source term for the energy equation of an incompressible heat transfer solver.
The equation I wish to implement would be the following :
\frac{\partial T}{\partial t}+u_{j}\frac{\partial T}{\partial x_{j}}=\frac{\partial}{\partial x_{i}}(\alpha_{eff}\frac{\partial T}{\partial x_{j}})+\frac{hS(T_{w}-T)}{\rho_{0}C_{p}V}
To do this, I modified the createFields.H of my solver to implement two volScalarFields, h and Tw.
To avoid taking into account the thermal contribution of the wall twice, alphaEff would be set to zero at the wall, and h and Tw set to zero anywhere but at the wall.
To implement this source term, I looked at fvOptions(T), however I could not find a way of implementing non-constant semi-implicit coefficients for the source term, thus I tried to implement it this way :
    fvScalarMatrix TEqn
        fvm::ddt(T)
      + fvm::div(phi, T)
      - fvm::laplacian(alphaEff, T)
       - fvm::Sp(h*Surface/(rho*Cp*Volume),T)+fvc::Sp(h*Surface /(rho*Cp*Volume),Tw)
with rho and Cp two scalars and Volume = mesh.V() and Surface = mesh.magSf().
My main problem is that the Sp() function allows as arguments a scalar and a volScalarField or volVectorField, and I cannot find a way to fit the surface and volume part into any of these types.
I tried to use a fvc::reconstructMag(mesh.magSf()) to transform the type of mesh.magSf() from a surfaceScalarField into a volScalarField, and also to create a volumeScalarField Volume in the createFields.H with Volume.ref() = mesh.V(), but to no avail.
Does anyone have an idea to get past this problem ?
Thanks in advance,
Matthieu
M.E. is offline   Reply With Quote
chtc, source term
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
