Phase Field Method & Diffuse Interface Modeling in FOAM
Like Tree3Likes
  • 3 Post By holger_marschall
Old   April 7, 2014, 02:50
Default Phase Field Method & Diffuse Interface Modeling in FOAM
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Hi FOAMers,
this is just to let you know that Xuan Cai (Karlsruhe Institute of Technology) and me (Center of Smart Interfaces, TU Darmstadt) are working on the implementation of phase field methods / diffuse interface models in FOAM.
In particular, we are aiming at conservative and bounded FV-based methods for the Allen-Cahn and Cahn-Hilliard equations for Direct Numerical Simulations of two-phase flows. The project's topic is on dynamic wetting, where diffuse interface modeling alleviates the known moving contact-line paradox (stress singularity at no-slip walls). However, with phase-field methods, also one could think of other (more exotic) interfacial physics (foaming, crystal growth, etc.), which certainly makes this model class very appealing.
The implementation employs the well-known strategy design pattern. We have chosen the difference of phase volume fractions as an order parameter, such that there are physical bounds within [-1, 1]. The Cahn-Hilliard equation is of fourth order so solution strategy comes into play (segregated/split vs. coupled), which directly bias the boundedness of the order parameter. While the Cahn-Hilliard equation exhibits inherent volume-conservation property, the Allen-Cahn equation needs to be appropriately constrained to this property. However, currently, we are able to obtain a relative volume-error of 1.3E-6 for a spreading droplet after 1.2E-2 seconds.
As an appetizer, allow me to attach some screenshots. At this stage, any comments/hints/ideas on implementation techniques you have heard of and on other test case (currently we examine the 'spreading droplet' and 'rising capillary' cases) are really appreciated...
best regards,
Holger
olivierG, Cyp and hadisafaei like this.
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   April 7, 2014, 03:31
Xuan Cai
cfd_explorer is on a distinguished road
Hi FOAMers,
I'd like to join Holger for appreciating your inputs/advices in advance
Best regards,
Xuan
cfd_explorer is offline   Reply With Quote
Old   June 7, 2014, 15:59
Hrushi
hrushi.397 is on a distinguished road
How did you manage to keep the parameter within bounds? How fine is your mesh?
Regards,
Hrushikesh
hrushi.397 is offline   Reply With Quote
Old   August 13, 2014, 11:16
Holger Marschall
Dear all,
just to give you a brief update. We are currently writing a paper describing the conservative Finite Volume discretisation of the Navier-Stokes Allen-Cahn and Cahn-Hilliard equations for two-phase flows. As for some test cases, we opted for dynamic wetting cases.
Please drop me a mail, if you are interested in a preprint. I will keep you posted on the progress.
best regards,
Holger.
PS.:
Originally Posted by hrushi.397 View Post
Dear Hrushikesh,
this is a natural outcome if you consider coupling in the momentum equation in order to take into account the relative density flux due to diffusion of components. ONLY this allows you to use conservative fluxes! With this, the boundedness property is then found to be consistently enforced (as an inherent property of the phase field transport equations).
The current implementation of this look very clean
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      - fvm::laplacian(mu, U)
      - (fvc::grad(U) & fvc::grad(mu))
      //-HM Coupling term
      - phaseField.diffRhoPhi(U)
      //- buoyancy and surface tension term
      //- tansferred to pressure equation
The nuts and bolts behind this will be described in the paper. I am also planing a release to Foam-Extend.
Hope this helps,
Holger
Holger Marschall
Old   June 25, 2015, 03:37
Rohith
RaghavendraRohith is on a distinguished road
Hi Holger,
I am trying to model a surface tension and wetting model in a closed capsule geometry using CLSVOF. I have tried different contact angles (Dynamic and static). The complexity of my problem lies in the incompressible nature of phase1 which is solid and wetting occurs post melting of the solid. The velocity is generally very low @ 1e-5 m/s and the also the pressure difference between two phases is also at the range of 30 Pa. Will your model help me in enhancing the nature of wetting in my defined problem?
Please find the attached Jpg.
VG,
Rohith
RaghavendraRohith is offline   Reply With Quote
Old   November 24, 2015, 09:10
Sebastian W.
nero235 is on a distinguished road
Send a message via ICQ to nero235
any news regarding the current state of the new phaseFieldFoam solver? I am very interested in working with this solver.
Kind regards, Sebastian
nero235 is offline   Reply With Quote
Old   November 25, 2015, 12:23
Edin Berberovic
eberberovic is on a distinguished road
Hi Sebastian,
I have found the solver phaseFieldFoam, which is I believe adopted by you:
https://github.com/11101011/phaseFieldFoam
Have you tested it, how does it perform? Exactly which paper is it referred to?
Regards,
Edin
eberberovic is offline   Reply With Quote
Old   November 25, 2015, 12:28
Edin Berberovic
Hi Holger,
Have you already released the diffuse interface solver, or when do you think it will be released?
Regards,
Edin
Old   November 26, 2015, 02:47
Sebastian W.
Originally Posted by eberberovic View Post
Hi Sebastian,
Regards,
Edin
Hello Edin,
yeah well this is the solver from Adam Donaldson, which I ported to a OF 2 version and uploaded it then to github However the version from Holger Marschall is very different, so I heard. I don't know if he has released the solver yet, that is why I am asking.
Kind regards,
Sebastian
Old   February 3, 2016, 02:57
Holger Marschall
Hi Edin, hi Sebastian,
yes definitely, we will release the source. It is planned for this year. I just want to write up a paper describing the model derivation and numerics.
P.S.: If somebody is familiar with phase-field modeling and works with FOAM please contact me. I am eager to see the framework working for other physics than for a capillary interface (i.e. two-phase flow of two immiscible Newtonian fluids taking into account interfacial energy). The code structure should be prepared and flexible enough for that.
best regards,
Holger
Holger Marschall
Old   February 4, 2016, 14:52
Cyp
Cyprien
Cyp is on a distinguished road
Hi Holger,
I am just curious, is your phase-field model subject to spurious currents at the gas/liquid interface?
It is still a bottleneck for VOF simulation in porous structures at very low capillary number (Ca = 10^-6 and below). The state of art techniques use filtering method, but as of today, nothing is really convincing.
Cheers,
Cyprien
Cyp is offline   Reply With Quote
Old   July 26, 2016, 12:37
Julien Maes
JULIEN MAES is on a distinguished road
Hi Holger,
Did you end up releasing the code?
Cheers,
Julien
JULIEN MAES is offline   Reply With Quote
Old   September 10, 2018, 05:24
Default phase field confusion
  #13
Qi Xueyu
winsway is on a distinguished road
i have some confusion with phase field and hope you solve my confusion.I don't know whether phase field is suitable for the calculation and simulation of multi-phase turbulence. Most of the literature is VOF and level set. I hope you can provide some help~
winsway is offline   Reply With Quote
Old   December 19, 2019, 00:54
Harish Dixit
hdixit is on a distinguished road
Hi Holger,
I was curious to know if you did release the phase-field code? We are very keen to use the code for some wetting calculations.
best regards,
Harish
hdixit is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
phase field or Cahn-Hilliard method dusky.he Main CFD Forum 3 February 2, 2006 16:43
