add a phase diffusion term in both continuity and monmentum equations for twoPhEuler
Old   February 4, 2020, 13:08
Question add a phase diffusion term in both continuity and monmentum equations for twoPhEuler
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi everone, Please help me to verify the code I wrote is reasonable or not, Thanks a lot.
I need to add a diffusion term (which is shown in the attached figure) in both Uequation and pequation for the twophaseeulerfoam. The code (bold words) I wrote is as shown in the fowllowing:
U1Eqn =
fvm::div(alphaRhoPhi1, U1) - fvm::Sp(fvc::div(alphaRhoPhi1), U1)
+ MRF.DDt(alpha1*rho1, U1)
+ - fvm::laplacian(alpha1*rho1*(1/(alpha1+0.001)*(rho2/rho1)*(2.5/beta*(pow(alpha2,-beta)-1)-alpha2)*phase2.turbulence().nu()+phase2.turbulence ().nut()), U1)
- fvm::div(rho1*phase2.turbulence().nut()/sigma*(fvc::grad(alpha1)), U1)
+ Vm*(UgradU1 - (UgradU2 & U2))
- fvOptions(alpha1, rho1, U1)
However, it cannot be compiled in a right way.
qi.yang@polimi.it is offline   Reply With Quote
Old   February 5, 2020, 05:09
Cyp
Cyprien
Cyp is on a distinguished road
If you modify the continuity equations, you have to change the pressure equations as well because the pressure equation derives from the continuity equations.
Regarding your compiling error, it is because you do not implement the divergence correctly. The first argument as to be a surface<something>Field : fvm::div(phiSomething,U1) and in your code you have a volVectorField.
Cheers,
Cyprien
Cyp is offline   Reply With Quote
Old   February 5, 2020, 05:20
kimy
Thanks a lot, Cyprien.. I also changed the mass conservation equation as shown following. But in my momentum equation, there is no phi existing. Could you please help me to see that pic I attached.
pEqnComp1 =
contErr1
- fvc::Sp(fvc::ddt(alpha1) + fvc::div(alphaPhi1), rho1)
)/rho1
+ (alpha1*psi1/rho1)*correction(fvm::ddt(p_rgh)) - fvc::laplacian(alpha1*phase2.turbulence().nut()/sigma);
pEqnComp2 =
contErr2
- fvc::Sp(fvc::ddt(alpha2) + fvc::div(alphaPhi2), rho2)
)/rho2
+ (alpha2*psi2/rho2)*correction(fvm::ddt(p_rgh)) - fvc::laplacian(alpha2*phase2.turbulence().nut()/sigma);
Old   February 5, 2020, 05:25
Cyp
Cyprien
fvc::snGrad(alpha1)
Old   February 5, 2020, 05:39
kimy
Really thanks. In terms of the pressure equations, there are some parts to be changed?
Old   February 5, 2020, 05:44
kimy
After I changed the code like this, the error occurs:
- fvm::div(rho1*phase2.turbulence().nut()/sigma*fvc::snGrad(alpha1), U1)
In file included from mytwoPhaseEulerFoam1.C:96:0:
pUf/UEqns.H: In function 'int main(int, char**)':
pUf/UEqns.H:32:82: error: no matching function for call to 'div(Foam::tmp<Foam::Field<double> >, Foam::volVectorField&)'
In file included from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/finiteVolume/fvm/fvmDiv.H:94:0,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/finiteVolume/fvm/fvm.H:45,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvm.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/cfdTools/general/include/fvCFD.H:10,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvCFD.H:1,
from mytwoPhaseEulerFoam1.C:33:
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/finiteVolume/fvm/fvmDiv.C:45:1: note: candidate: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
Old   February 5, 2020, 05:49
Cyp
Cyprien
You have to re-derive the PISO algorithm to check if you need further modifications. You might need to add some terms during the correction of the velocities but I am not sure. The only way to check that is to rederive the PISO with your modifications.
surfaceScalarField phiSomething
    "phiSomething",
     rho1*fvc::interpolate(phase2.turbulence().nut())/sigma*fvc::snGrad(alpha1)
fvm::div(phiSomething, U1);
Old   February 5, 2020, 06:10
kimy
I am confused that both U equation and P equation are based on the surface field?
pEqnComp1 =
contErr1
)/rho1
The bold words are not right? But I complied successfully.
Sorry, I saw the code in the pressure equation:
// Phase-fraction face-gradient
surfaceScalarField snGradAlpha1(fvc::snGrad(alpha1)*mesh.magSf());
should I multiply mesh.magSf()) in my code?
Old   February 5, 2020, 07:26
Cyp
Cyprien
The first argument of divergence has to be a surface field.
You might need it indeed. You will see at the execution if you have an error of dimensions.
Old   February 5, 2020, 07:52
kimy
The following is the original code for UEquation, but divDevRhoReff(U2) is not the surface field?
U2Eqn =
fvm::ddt(alpha2, rho2, U2) + fvm::div(alphaRhoPhi2, U2)
- fvm::Sp(contErr2, U2)
+ MRF.DDt(alpha2*rho2 + Vm, U2)
+ phase2.turbulence().divDevRhoReff(U2)
- Vm
fvm::ddt(U2)
+ fvm::div(phi2, U2)
- fvm::Sp(fvc::div(phi2), U2)
- DDtU1
+ fvOptions(alpha2, rho2, U2)
template<class BasicTurbulenceModel>
Foam::tmp<Foam::fvVectorMatrix>
Foam::linearViscousStress<BasicTurbulenceModel>::d ivDevRhoReff
const volScalarField& rho,
volVectorField& U
) const
return
- fvc::div((this->alpha_*rho*this->nuEff())*dev2(T(fvc::grad(U))))
- fvm::laplacian(this->alpha_*rho*this->nuEff(), U)
In my code, I replace the divDevRhoReff(U2) by the following code,
- fvm::laplacian(alpha2*rho2*(1/(alpha1+0.001)*(rho2/rho1)*(2.5/beta*(pow(alpha2,-beta)-1)-alpha2)*phase2.turbulence().nu()+phase2.turbulence ().nut()), U2)
is there any problem?
Old   February 5, 2020, 07:58
Cyp
Cyprien
no problem as far as I can see.
You should have a look at the Programmer's Guide. All these points are discussed there.
Old   February 5, 2020, 08:03
kimy
    "phiSomething",
I tried this but it faild again.
Old   February 5, 2020, 08:09
Cyp
Cyprien
what do you mean "it failed"?
Old   February 5, 2020, 08:12
kimy
Sorry. I mean "failed"
pUf/UEqns.H:18:5: error: no matching function for call to 'Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricField(const char [13], Foam::tmp<Foam::Field<double> >)'
In file included from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.H:660:0,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricField.T.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricScalarField/GeometricScalarField.T.H:38,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricScalarField.T.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricFields.T.H:34,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricFields.T.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/fields/volFields/volFields.H:37,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/volFields.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/interpolation/surfaceInterpolation/surfaceInterpolationScheme/surfaceInterpolationScheme.C:27,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/interpolation/surfaceInterpolation/surfaceInterpolationScheme/surfaceInterpolationScheme.H:307,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/interpolation/surfaceInterpolation/surfaceInterpolation/surfaceInterpolate.H:41,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/surfaceInterpolate.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/finiteVolume/fvc/fvc.H:39,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvc.H:1,
from J:/blueCFD-Core-2017/OpenFOAM-5.x/src/finiteVolume/cfdTools/general/include/fvCFD.H:8,
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:678:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::wordList = Foam::List<Foam::word>]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:678:1: note: candidate expects 4 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:635:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::wordList = Foam::List<Foam::word>]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:635:1: note: candidate expects 4 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:601:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::word&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:601:1: note: candidate expects 3 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:571:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:571:1: note: no known conversion for argument 2 from 'Foam::tmp<Foam::Field<double> >' to 'const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&'
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:539:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:539:1: note: no known conversion for argument 2 from 'Foam::tmp<Foam::Field<double> >' to 'const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&'
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:507:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:507:1: note: no known conversion for argument 1 from 'const char [13]' to 'const Foam::IOobject&'
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:475:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:475:1: note: no known conversion for argument 1 from 'const char [13]' to 'const Foam::IOobject&'
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:446:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:446:1: note: candidate expects 1 argument, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:415:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:415:1: note: candidate expects 1 argument, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:378:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:378:1: note: candidate expects 3 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:343:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:343:1: note: no known conversion for argument 1 from 'const char [13]' to 'const Foam::IOobject&'
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:317:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::Field<Type>&, const Foam::PtrList<PatchField<Type> >&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:317:1: note: candidate expects 5 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:293:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Internal&, const Foam::PtrList<PatchField<Type> >&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Internal = Foam:imensionedField<double, Foam::surfaceMesh>]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:293:1: note: candidate expects 3 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:266:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Type>&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh; Foam::wordList = Foam::List<Foam::word>]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:266:1: note: candidate expects 5 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:240:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:240:1: note: candidate expects 4 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:215:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh; Foam::wordList = Foam::List<Foam::word>]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:215:1: note: candidate expects 5 arguments, 2 provided
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:191:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::word&) [with Type = double; PatchField = Foam::fvsPatchField; GeoMesh = Foam::surfaceMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.T.C:191:1: note: candidate expects 4 arguments, 2 provided
make: *** [/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/rules/General/transform:26: Make/mingw_w64GccDPInt32Opt/mytwoPhaseEulerFoam1.o] Error 1
Old   February 5, 2020, 08:29
Cyp
Cyprien
are rho1 and sigma dimensionedScalar of volScalarField ?
Old   February 5, 2020, 08:36
kimy
rho1 is the density of phase1 (dimensioned volume scalar) sigma is defined by me, which is a dimensonless constant.
Old   February 5, 2020, 08:43
Question
  #17
kimy
    "phiSomething",
Sorry, I am not so familiar with numerical scheme. I found one equation described here. When we should regard one term as a source term rather than add it directly in the equation?
solve( fvm::laplacian(k, T) + fvm::Sp(sp, T) )
Old   February 5, 2020, 10:54
Cyp
Cyprien
but are they declared as volScalarField or as dimensionedScalar ?
Old   February 5, 2020, 11:59
kimy
sigma I defined like the following in createfields:
dimensionedScalar sigma("sigma", dimViscosity/dimViscosity, mytransportProperties);
In fact, it is dimensionless.
Old   February 5, 2020, 12:23
kimy
I think I solved the problem with the following code:
- fvc::div(fvc::grad(alpha1)*rho1*phase2.turbulence( ).nut()/sigma*U1)
it was compiled successfully and I ran the test case. The results seem resonable.
However, I doubt that whether I need write the code like:
- fvc::Sp(div(fvc::grad(alpha1)*rho1*phase2.turbulen ce().nut()/sigma, U1))
Because I found the following two codes will lead different results.
solve( fvm::laplacian(k, T) + fvc::Sp(sp, T) );
solve( fvm::laplacian(k, T) + sp*T );
However, when I wrote - fvm::Sp(div(fvc::grad(alpha1)*rho1*phase2.turbulen ce().nut()/sigma, U1)), it failed to be compiled.
multiphaseflow, twophaseeulerfoam
