the difference between rho() and rho_ and rho?
Like Tree1Likes
  • 1 Post By HPE
Old   February 13, 2020, 06:22
Question the difference between rho() and rho_ and rho?
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi guys,
please help me to understand why in the k-epsilon source code there are so many simbols which may represent the same thing. For example, rho() and rho_ and rho. What do they mean?
tmp<fvScalarMatrix> epsEqn
fvm::ddt(alpha, rho, epsilon_)
+ fvm::div(alphaRhoPhi, epsilon_)
- fvm::laplacian(alpha*rho*DepsilonEff(), epsilon_)
C1_*alpha()*rho()*G*epsilon_()/k_()
//- fvm::SuSp(((2.0/3.0)*C1_ - C3_)*alpha()*rho()*divU, epsilon_)
- fvm::Sp(C2_*alpha()*rho()*epsilon_()/k_(), epsilon_)
+ epsilonSource()
+ fvOptions(alpha, rho, epsilon_)
Thanks!
qi.yang@polimi.it is offline   Reply With Quote
Old   February 13, 2020, 16:28
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- Wherever you see a tailing underscore in OF source code, that means the object is 'local' to the class.
- rho is 'volScalarField' type object for fluid density. This object includes 'internalField' and 'boundaryField' info.
- rho() in the source terms is 'volScalarField::Internal' type object wherein the boundary information is absent. This is fairly new functionality, and it is useful to reduce computational costs for parallel computations by reducing parallel communications which are mostly needed for boundaryFields rather than internalFields.
For a given 'vol*Field', say 'Object', '()' operator is defined, and you can call it by appending it to the given field, like 'Object()'. This 'Internal' field is only usable for sources on the right hand side of a constructed equation.
lpz456 likes this.
HPE is offline   Reply With Quote
Old   February 14, 2020, 03:30
Question
kimy
Thanks. So if I write rho(), rho or rho_ will lead the results different only in the boundary?
Old   February 14, 2020, 15:16
HPE
HPE's Avatar
What do you mean by "results"? These objects are implementation details, and allowing tricks to reduce comp costs. Apart from that, all three objects represent the same information eventually: fluid density.
turbulence model
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 10:26
rho and rhoFinal in fvSolution and others NewKid OpenFOAM Running, Solving & CFD 3 July 15, 2019 09:36
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 06:59
what does this verbose error mean? immortality OpenFOAM Running, Solving & CFD 1 February 6, 2013 16:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
