const volVectorField& U = db().lookupObject<volVectorField>("U") gives runtime error
Old   July 28, 2014, 17:26
Default const volVectorField& U = db().lookupObject<volVectorField>("U") gives runtime error
kumar
kumar2 is on a distinguished road
Hi All,
I am trying to access the points in the mesh inside the linearSpring class.
So inside the linearSpring.C , (under the restrain member function), I do the
following modifications,
////////////////Mods. to linearSpring.C//
const objectRegistry& db();
const volVectorField& U = db().lookupObject<volVectorField>("U"); //Line2
const fvMesh & mesh = U.mesh(); //Line3
const pointField & pp = mesh.points(); //Line4
The libary compiles with out errors, but when I use this in a solver(waveDyMFoam), it gives the
following run time errors. I also found that if I comment out Lines 2 to 4 , the run time error
disappears.
///////RUN TIME ERROR////
waveDyMFoam: symbol lookup error: /share/gecko/krishnak/OpenFOAM/krishnak-2.1.0/
platforms/linux64GccDPOpt/lib/mylibforcesNEW.so: undefined symbol: _Z2dbv
Any suggestion is welcome
Thanks in advance
Kumar
kumar2 is offline   Reply With Quote
Old   July 29, 2014, 03:35
Jacques F.
Jacks is on a distinguished road
What is in your Make/files and Make/options ?
Jacks is offline   Reply With Quote
Old   July 29, 2014, 15:17
kumar
Hi Jacks,
Thanks for your quick reply.
Make/options is :
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude
LIB_LIBS = \
-lincompressibleTransportModels \
-lincompressibleRASModels \
-lincompressibleLESModels \
-lbasicThermophysicalModels \
-lspecie \
-lcompressibleRASModels \
-lcompressibleLESModels \
-lfiniteVolume \
-lmeshTools \
-lsampling
Make/files
forces/forces.C
forces/forcesFunctionObject.C
forceCoeffs/forceCoeffs.C
forceCoeffs/forceCoeffsFunctionObject.C
sDoFRBM = pointPatchFields/derived/sixDoFRigidBodyMotion
$(sDoFRBM)/sixDoFRigidBodyMotion.C
$(sDoFRBM)/sixDoFRigidBodyMotionIO.C
$(sDoFRBM)/sixDoFRigidBodyMotionState.C
$(sDoFRBM)/sixDoFRigidBodyMotionStateIO.C
sDoFRBMR = $(sDoFRBM)/sixDoFRigidBodyMotionRestraint
$(sDoFRBMR)/sixDoFRigidBodyMotionRestraint/sixDoFRigidBodyMotionRestraint.C
$(sDoFRBMR)/sixDoFRigidBodyMotionRestraint/sixDoFRigidBodyMotionRestraintNew.C
$(sDoFRBMR)/linearAxialAngularSpring/linearAxialAngularSpring.C
$(sDoFRBMR)/linearSpring/linearSpring.C
$(sDoFRBMR)/sphericalAngularSpring/sphericalAngularSpring.C
$(sDoFRBMR)/tabulatedAxialAngularSpring/tabulatedAxialAngularSpring.C
sDoFRBMC = $(sDoFRBM)/sixDoFRigidBodyMotionConstraint
$(sDoFRBMC)/sixDoFRigidBodyMotionConstraint/sixDoFRigidBodyMotionConstraint.C
$(sDoFRBMC)/sixDoFRigidBodyMotionConstraint/sixDoFRigidBodyMotionConstraintNew.C
$(sDoFRBMC)/fixedAxis/fixedAxis.C
$(sDoFRBMC)/fixedLine/fixedLine.C
$(sDoFRBMC)/fixedOrientation/fixedOrientation.C
$(sDoFRBMC)/fixedPlane/fixedPlane.C
$(sDoFRBMC)/fixedPoint/fixedPoint.C
pointPatchFields/derived/sixDoFRigidBodyDisplacement/sixDoFRigidBodyDisplacementPointPatchVectorField.C
pointPatchFields/derived/uncoupledSixDoFRigidBodyDisplacement/uncoupledSixDoFRigidBodyDisplacementPointPatchVect orField.C
LIB = $(FOAM_USER_LIBBIN)/mylibforcesNEW
What area your thoughts?
Thanks in advance
Kumar
Old   July 30, 2014, 05:16
Jacques F.
I thought it might be due to linking error while compiling waveDyMFoam, so in Make/options file of your waveDyMFoam solver not mentioning correctly your
mylibforcesNEW.so library.
Old   July 30, 2014, 22:55
kumar
Hi Jacks,
I tried out your suggestion, i.e, I recompiled the waveDyMFoam with the library (instead of calling the library at real time in the controlDict of waveDyMFoam, as a dynamic linked library, which I did first) and I get this error.
// ERROR//
/share/gecko/krishnak/OpenFOAM/krishnak-2.1.0/platforms/linux64GccDPOpt/lib/libmylibforcesNEW.so: undefined reference to `db()
I implemented the new code starting with, {const objectRegistry& db();
const volVectorField& U = db().lookupObject<volVectorField>("U"); } .., inspired by this post http://www.cfd-online.com/Forums/ope...tml#post254642 , but reading more closely and going through fvPatchField.H, I found that db is already defined in that class and that may be the reason they are able to access it. However in the linearSpring class , no db ( or similar) is defined. Also no db is defined in the class above linearSpring ( sixDoFRigidBodyMotionRestraints ). At this point I am not sure how to proceed. Once again, If you can give any pointers on how to proceed, that would be great.
Thanks a lot
Kumar
Old   March 6, 2020, 21:41
tooran
tooran is on a distinguished road
Originally Posted by kumar2 View Post
Hi All,
disappears.
Thanks in advance
Kumar
use this following line.
const fvMesh& mesh = U_.mesh();
tooran is offline   Reply With Quote
Old   March 9, 2020, 00:01
Yogesh Bapat
ybapat is on a distinguished road
You need to access db using function in mesh. Check functions in fvMesh for this.
ybapat is offline   Reply With Quote
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
RunTim Error for simpleFoam Djub OpenFOAM Running, Solving & CFD 2 April 12, 2013 11:51
how to change a volScalarField in bc? Katl OpenFOAM Programming & Development 20 February 2, 2012 06:10
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
