May 10, 2020, 00:51 |
volPointInterpolation error
krishna kant
Rep Power: 10 |
Hello All,
I am trying to interpolate the interface vector in my two phase flow solver (CLSVOF by chalmers group) by volPointInterpolation. My code: Code:
{ // calculate normal vector gradPsi == fvc::grad(psi); volPointInterpolation vpi(mesh); //error is coming in this line pointVectorField pointn1 = vpi.interpolate(gradPsi); forAll(mesh.cells() , idCell){ gradPsi[idCell] = interpolatePointToCell(pointn1, idCell);} } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 3.1e-3; vertices ( (0 0 0) (15 0 0) (15 8 0) (0 8 0) (0 0 8) (15 0 8) (15 8 8) (0 8 8) ); blocks ( hex (0 1 2 3 4 5 6 7) (200 125 125) simpleGrading ( ( (0.4 0.125 0.125) (0.2 0.75 1) (0.4 0.125 8) ) ( (0.375 0.1 0.125) (0.25 0.8 1) (0.375 0.1 8) ) ( (0.375 0.1 0.125) (0.25 0.8 1) (0.375 0.1 8) ) ) ); edges ( ); boundary ( bottom { type patch; faces ( (1 5 4 0) ); } top { type patch; faces ( (3 7 6 2) ); } left { type patch; faces ( (0 4 7 3) ); } right { type patch; faces ( (2 6 5 1) ); } front { type patch; faces ( (3 2 1 0) ); } back { type patch; faces ( (6 7 4 5) ); } ); mergePatchPairs ( ); // ************************************************************************* // #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? at sigaction.c:? #3 Foam::volPointInterpolation::makeInternalWeights(F oam::Field<double>&) at ??:? #4 Foam::volPointInterpolation::makeWeights() at ??:? #5 Foam::volPointInterpolation::volPointInterpolation (Foam::fvMesh const&) at ??:? #6 ? at ??:? #7 __libc_start_main at ??:? #8 ? at ??:? Segmentation fault (core dumped) Any help is deeply appreciated. |
May 16, 2020, 08:53 |
krishna kant
Rep Power: 10 |
The mesh is a dynamic Mesh and it seems that is the root cause for the error. How should I modify my code for this?
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
