How to represent laplacian of a product of multiple terms?
Like Tree1Likes
  • 1 Post By deepbandivadekar
Old   February 14, 2019, 11:44
Default How to represent laplacian of a product of multiple terms?
Deep
deepbandivadekar is on a distinguished road
\frac{\partial \rho U}{\partial t} + \bigtriangledown \bullet \phi U - \bigtriangledown \bullet \mu\bigtriangledown U = -\bigtriangledown p
This is represented as
solve
fvm::ddt(rho, U)
+ fvm::div(phi, U)
- fvm::laplacian(mu, U)
- fvc::grad(p)
Specifically, where laplacian operator is used, it's a product of phi and U (only two terms).
My question is: How to represent laplacian of an expression which involves product of more terms involving various operators. e.g.
\bigtriangledown \bullet \frac{X}{Y} \mid Z\mid \bigtriangledown U
I know that following is not right:
fvm::laplacian((X/Y*mag(Z)), U)
rarnaunot likes this.
deepbandivadekar is offline   Reply With Quote
Old   February 14, 2019, 11:54
Andrew Somorjai
massive_turbulence is on a distinguished road
solve
fvm::ddt(rho, U)
+ fvm::div(phi, U)
- fvc::grad(p)
I'm not sure if this is right but fvm::Sp() solves this implicitly so that it adds to the diagonal matrix so basically you would do something like
fvm::Sp( fvc::laplacian((X/Y*mag(Z)), U)?
Notice I have fvc so that it solves for the laplacian explicit and then it multiplies U and that goes to the diagonal, but once again I've never tried this so that might be wrong.
massive_turbulence is offline   Reply With Quote
Old   February 14, 2019, 12:07
Deep
Thanks for a quick reply. But no, this doesn't work.
The error is:
error: no matching function for call to ‘Sp(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’
and further below:
note:   candidate expects 2 arguments, 1 provided
But we've provided both arguments! (", U)")
Old   February 14, 2019, 12:24
Andrew Somorjai
The error is:
and further below:
I'm just curious if fvm::laplacian compiles?
There's also SuSp fvMatrix, fvOptions and SuSp: automatic implicit/explicit source-term treatment
Old   February 14, 2019, 12:32
Deep
Well, without the Sp, it sure did compile earlier. But wasn't successful in running a case. From the crash error I was sure it was about the way it is represented. SuSp is just about distinguishing implicit/explicit, I believe.
The core issue I think is handling this term here: "X/Y * mag(Z)".
Old   February 14, 2019, 12:38
Andrew Somorjai
The magnitude must be messing up the parsing or something. It works with X/Y right?
Old   February 14, 2019, 12:41
Deep
Well I was thinking the same. But I just tried and no. Compilation fails with same errors again. Needs one more argument ().
Old   February 14, 2019, 12:48
Andrew Somorjai
With fvm::Sp or just fvm::laplacian, lets keep it simple. Maybe the fvSchemes file isn't correct?
Old   February 14, 2019, 12:56
Deep
Compilation worked with simple fvm::laplacian in my first post. But case failed citing wrong dimensions. This was bound to happen because I was prompted to have a term in fvSchemes for a physically unrealistic quantity (e.g. laplacian of X/mag(Z)*mag(Z) instead of expected laplacian of X/mag(Y)*mag(Z).. as in the original expression). This led me think I'm not representing it right.
With fvm::Sp it never managed to compile. Same error everytime. I just also tried changing the sequence of Sp and laplacian. Doesn't work.
fvm::laplacian(fvc::Sp(1/Y, fvc::Sp(X,mag(Z))), U)
Last edited by deepbandivadekar; February 14, 2019 at 13:02. Reason: Not div, laplacian
Old   February 14, 2019, 13:06
Andrew Somorjai
Could it be possible to solve for this term "X/Y * mag(Z)" outside of the laplacian or sp and then put that variable into the laplacian?
Old   February 14, 2019, 13:27
Deep
Hmm, that's a good idea. Tried this. Compiler doesn't give any problems. Case still is stuck.
Weird error:
--> FOAM FATAL IO ERROR:
keyword laplacian(laplacian(
 file: <path to case folder>/system/fvSchemes.laplacianSchemes from line 37 to line 41.
There is no syntax error in fvSchemes, I checked.
What does that even mean!?
Old   February 14, 2019, 14:47
Andrew Somorjai
Weird error:
Weird, I was thinking it was maybe a type error with X Y or Z not being differentiable but now it compiles which implies it's not a type error? I honestly don't know enough about the schemes myself so unless someone helps beyond here I'm "game over" .
If you could post your schemes file that might help someone see something that was overlooked or maybe you could just upload the parts of your project that are necessary to see the problem, not the whole thing (unless you don't mind). Best regards!
Old   February 15, 2019, 08:58
Deep
Thanks for your help so far nonetheless. I also tried to change the order of terms and it doesn't change the situation much.
I'll try to share more if I can soon.
Old   February 15, 2019, 10:54
Andrew Somorjai
I'm wondering if you can represent the Laplacian in terms of the grad and div instead and try that by breaking down the equation for the X/Ymag(Z) term.
Basically you solve for that part separately and then solve the Laplacian by taking the divergence of the gradient literally.
Old   February 18, 2019, 11:04
Deep
I'm not quite following you. I mean I don't see the math behind this. I managed to get rid of this error, however now I have a dimension mismatch when solving a case. Which is absolutely absurd. I have checked the units hundred times now but I think it doesn't interpret the terms as I think they are interpreted.
So, I was wondering if there's any way to print the dimensions of a certain quantity (with or without the value) as the solver runs? I bumped up an old thread here if you want to see what I mean.
Old   March 17, 2020, 10:09
Rosario Arnau
rarnaunot is on a distinguished road
deepbandivadekar
Dear deepbandivadekar,
Have you solved your problem?
I would like to ask you if fvm::laplacian can have three terms or it just can have 2 terms.
Have you tried with something like this?
      - fvm::laplacian
            fvc::interpolate(alpha)
           *fvc::interpolate(this->turbulence().nut()*rho/Sc_),
            Yi
This appears in https://github.com/OpenFOAM/OpenFOAM...ntPhaseModel.C
Actually, I'm not sure what fvc::interpolate does but there's a product and division at the second term nut*rho/Sc ....
Regards,
rarnaunot is offline   Reply With Quote
MULES with source terms and multiple phases tgvosk OpenFOAM Running, Solving & CFD 8 March 21, 2018 06:14
Question in definition of terms in solve titio OpenFOAM Running, Solving & CFD 0 March 19, 2009 16:02
Doubts on how to represent some terms for viscoelastic Flow Simulation titio OpenFOAM Running, Solving & CFD 0 February 4, 2009 07:42
Multiple species and UDS source terms Ale FLUENT 2 September 9, 2002 03:45
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
