MembraneFOAM RO BC warning
Like Tree2Likes
  • 2 Post By alexeym
Old   March 25, 2020, 11:17
Default MembraneFOAM RO BC warning
JF.R.Piche is on a distinguished road
Hello everyone,
I'm trying to use the reverse osmosis boundary condition from MembraneFOAM, but I'm getting a warning when compiling.
I'm using OpenFOAM v1912, and I dl the branch OF5 from MembraneFOAM git, available here, as suggested in a previous thread. I already did some changes :
- syntax of writeIfDifferent function, which I copy-pasted from another BC (something like writeIfDifferent<word>( os , ... ) became os.writeIfDifferent<word>( ... ) )
- deleted the reference to the triSurface lib (because it's not in src anymore, I'll try with a dummy case see if it's a problem)
- deleted the fm_ attribute and the calcFaceMapping() function. This is because I would like to use it as a boundary, and not a baffle.
I essentially need the RO BC, so that's where we'll stick for now (except if something else is needed).
So I want to compile the RO BC (sources files are attached), and I get a warning related to each constructor, as following :
RO_BC/explicitROmembraneSolute/explicitROmembraneSoluteFvPatchScalarField.C:136:18:  warning:  ‘Foam::dimensioned<Type>::dimensioned(Foam::Istream&) [with  Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations]
     GBC_(p.size())
In file included from /home/leo/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dimensionedType.H:565:0,
                 from /home/leo/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/DimensionedField.H:46,
                 from /home/leo/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude/fvPatchField.H:51,
                 from RO_BC/explicitROmembraneSolute/explicitROmembraneSoluteFvPatchScalarField.H:65,
                 from RO_BC/explicitROmembraneSolute/explicitROmembraneSoluteFvPatchScalarField.C:27:
/home/leo/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dimensionedType.C:275:1: note: declared here
 Foam::dimensioned<Type>::dimensioned(Istream& is)
Here GBC is defined as
        //- gradientBoundaryCoefficients
        Field<scalar> GBC_;
and the constructor involed is :
explicitROmembraneSoluteFvPatchScalarField::explicitROmembraneSoluteFvPatchScalarField
    const fvPatch& p,
    const DimensionedField<scalar, volMesh>& iF,
    const dictionary& dict
    fvPatchField<scalar>(p, iF),
    transProps_
        IOobject
            "transportProperties",
            this->db().time().constant(),
            this->db(),
            IOobject::MUST_READ,
            IOobject::NO_WRITE,
            true
    UName_(dict.lookupOrDefault<word>("U", "U")),
    R_(readScalar(dict.lookup("R"))),
    D_AB_Min_(transProps_.lookup("D_AB_Min")),
    D_AB_Coeff_(transProps_.lookup("D_AB_Coeff")),
    D_AB_mACoeff_(transProps_.lookup("D_AB_mACoeff")),
    rho0_(transProps_.lookup("rho0")),
    rho_mACoeff_(transProps_.lookup("rho_mACoeff")),
    VIC_(p.size()),
    VBC_(p.size()),
    GIC_(p.size()),
    GBC_(p.size())
    if (dict.found("value"))
        fvPatchField<scalar>::operator=
            scalarField("value", dict, p.size())
    else
        // initialise the field to 0.0 if no information is given
        fvPatchField<scalar>::operator=(pTraits<scalar>::zero);
From what I understood so far, that mean that the dimensionedDouble class doesn't exist anymore. But I'm never calling one on them. However, I do call dimensionedScalar, and it could be that Scalar = Double (if think I read it somewhere in my researches).
Even if it's not a critical problem (I can compile) I would be interested to correct this, and my very basic knowledge of C++ doesn't allow me to do so.
Thank you in advance for your help!
Léo
JF.R.Piche is offline   Reply With Quote
Old   March 26, 2020, 04:23
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If fact the warning is about these lines:
they should become:
    D_AB_Min_("D_AB_Min", transProps_),
You can find correct constructor here: https://openfoam.com/documentation/g...mensioned.html.
JF.R.Piche and Liangyuan like this.
alexeym is offline   Reply With Quote
Old   March 26, 2020, 04:41
Smile
Indeed, it works!
Thank you very much for your help!
For anyone passing by, I might commit these change to MembraneFoam in the future!
Léo
boundary condition, membrane, programming, reverse osmosis
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 00:53
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
