Accessing the field values of a mesh within another mesh |
June 16, 2022, 06:06 |
#1 | ||||
Mohsen Hashemzadeh
Dear Foamers,
I am developing a new solver for fire modelling based on FireFOAM. I need to have two different regions (meshes). In the larger one (called environment) I have to solve a set of governing equations (PDEs). For the other region (solid region), which should be embedded inside the environment region, I have to solve a set of ODEs. I know how to define two meshes and they work. The governing equations of each region are also working. The only thing is that I want to access the field values (say velocity, temperature, ...) of the environment region inside the solid region to somehow couple the fields of each region. I have two meshes, the definition of the meshes are based on the below link which I found useful: As FireFoam is a complex solver and there are numerous variables, it is not easy to define two fields (for each region) for all of the variables. Instead, I am looking for a way that I could access the data of the other field. To explain a bit more, I have two meshes (mesh and emMesh, same as the link above). On the mesh, the gas phase equations are solved, while on the emMesh, I have a couple of fields that should be solved. I tried to access the mesh while solving the solid region equation (i.e. emMesh using Quote:
Please kindly help. |
June 20, 2022, 04:09 |
Mark Olesen
Rep Power: 40 |
It helps if you think of the mesh regions layout like a tree:
Time | |-- region1 |-- region2 |-- ... \-- regionN From your current mesh region, you first need to access its time() parent after which you can do a lookup for any of its siblings. |
multi regions, multiple meshing, objectregistry |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Mapping values from 2D mesh to 3D mesh boundary during runtime | benk | OpenFOAM Programming & Development | 1 | June 13, 2014 02:39 |
